Minnesota Chapter Join Chapter, Leader: fordpower88
Spindle Nut Socket
Old 05-10-2010, 02:58 PM
msmenne17's Avatar
msmenne17
msmenne17 is offline
Spindle Nut Socket
I am having a helluva time finding this dumb thing. I've been to almost every auto parts store and nobody has the correct size. I tried AutoZone, Advance Auto Parts, O'reilly, Napa, Auto Value and a tool shop.
Anyone know where I can get one or borrow?
I need a 6 lug/prong socket. Probably 2 7/8" (the 2 5/8" at the parts stores is too small).
I live in So. MN just south of Mankato.
Old 05-10-2010, 03:38 PM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
I wish I could be of some kind of help for you Michael except to say good luck. How much of an emergency is this? Is this your only transportation or can it sit for a day or two until we can locate you one?
Old 05-10-2010, 03:51 PM
msmenne17's Avatar
msmenne17
I'd say it's urgent, but not an absolute emergency. I borrowed one from AutoZone this weekend only to find it was too small. When I had the tire off, I noticed the rotor has hairline cracks all over it.
This is my daily driver, so I'd like to get it done SOON.
Old 05-10-2010, 04:07 PM
mndiesel's Avatar
mndiesel
mndiesel is offline
In your location I would call Snap on or mac tool hqtrs and ask for a number of a local dealer and get one from them. They pretty much carry anything, I know I used to do that. Good luck on your search......
Old 05-10-2010, 05:59 PM
dlibson's Avatar
dlibson
dlibson is offline
Tom's idea is best for fast...
I probably have what you need in my tool box, but I'm not all that close to you...
Old 05-11-2010, 02:18 PM
msmenne17's Avatar
msmenne17
ok. I finally figured out what my issue was. I was looking at the Hub Body that is simply held in by a snap ring. Since I've never taken apart a hub before, I was going completely off of descriptions.
The Spindle Nut I was looking for sits behind the Hub Body. The Hub Body simply slides out of the hub after the snap ring is removed.
AutoZone's repair guides weren't functioning so I couldn't see anything from there. They aren't always 100% correct either. Last night I finally found someone on FTE (I think) that had posted a Ford procedure guide with expanded views of the axle/hub/rotor assembly. I have all of the parts and things I need (I think). I'm going to tackle this tonight. I had to go buy a BFH to seperate the hub from the rotor and get the wheel studs out of the hub/rotor assembly. We'll see how much of a pain the rust is to me.
I sprayed it with with some Liquid Wrench this weekend so it's had a couple days to sit and penetrate. This stuff has been AMAZING. I twisted a torx head for my socket set a while back. Sprayed this stuff on it and let it sit for a couple days. Came back with the same twisted torx head and everything came apart nice and easy.
Old 05-28-2010, 02:54 PM
DieselCamper01
Any luck on this project Michael?
Old 05-28-2010, 10:35 PM
msmenne17's Avatar
msmenne17
Yup.. got it done a couple weekends ago. Took about 7-8 hours in total.
Old 10-08-2011, 12:05 PM
kurtm96's Avatar
kurtm96
kurtm96 is offline
spindle nut socket
having the same problem that msmrnne17 had cannot find a 2.875in outside 6 prong socket for my 96 bronco
Old 10-08-2011, 04:47 PM
msmenne17's Avatar
msmenne17
Make sure your aren't looking at the Hub. The spindle nut sits behind the Hub. The hub is held in by a also ring. Once the snap ring is out, the hub will simply slide out, exposing the spindle nut.
Old 10-09-2011, 10:35 AM
kurtm96's Avatar
kurtm96
kurtm96 is offline
thanks for the info. i,m going outside now and take a better look at it.
Jeremy Morgan
06-07-2017 02:55 AM
Eli1644
02-02-2017 05:41 PM
snakedoc
04-24-2011 10:45 PM
gliattall
10-23-2009 07:41 PM
Quick Reply: Spindle Nut Socket
