Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- How to Reset Your Change Oil Light
Step by step instructions for do-it-yourself repairs
reset oil change light
Preferred method (to avoid embarassment)
1. Open glove compartment
2. Find strange sized paperback provided with vehicle
3. Confirm it has Ford F150 Owner's Manual written on the front
4. Skim book for relevant topic
5. Follow instructions
Alternate method (to encourage harassment)
Depending on your truck (thanks for all the information by the way), it's on page 91 or 103.
Oops, too late, you have already selected the alternate method...
sigh lol ok well deserved but cant find the dam thing lol
STANDARD MESSAGE CENTER (IF EQUIPPED)
With the ignition in the on position, the message center, located on your
instrument cluster, displays important vehicle information through a
constant monitor of vehicle systems. You may select display features
on the message center for a display of status preceded by a brief
indicator chime. The system will also notify you of potential vehicle
problems with a display of system warnings followed by a long indicator
chime.
Selectable features
Press and release the SELECT/RESET stem, located in the speedometer,
to scroll and reset the following functions. Select or reset the function by
pressing and holding the SELECT/RESET stem for more than two
seconds.
Setup Menu
Press and hold the SELECT/RESET stem to get into the SETUP menu
sequence from the INFO menu for the following items:
• Oil Life
• Units (English/Metric)
• Rear Park Aid (if equipped)
• Autolamp (if equipped)
• Autolock (if equipped)
• Autounlock (if equipped)
• Easy Entry (if equipped)
• Trailer Sway (if equipped)
• Language
• Reset to English–if in another language (see Note below)
Note: When returning to the
SETUP menu and a non-English
language has been selected, HOLD
RESET FOR ENGLISH will be
displayed to change back to English.
stem to change back to English.
Oil Life XXX% HOLD RESET = NEW
An oil change is required whenever indicated by the message center.
USE ONLY RECOMMENDED ENGINE OILS.
To reset the oil monitoring system to 100% after each oil change
[approximately 7,500 miles (12,000 km) or six months] perform the
following:
1. Press and release the
SELECT/RESET stem to display OIL
LIFE = XXX% HOLD RESET =
NEW.
2. Press and hold the
SELECT/RESET stem for two
seconds and release. Oil life is set to
100% and “OIL LIFE SET TO 100%”
is displayed.
3. While “OIL LIFE SET TO 100%”
is displayed, if a lower oil life start value is desired, press and release the
RESET control to reduce the start value. Each press of the
SELECT/RESET stem reduces the value by 10 percent.
Note: Oil life start value of 100% equals 7,500 miles (12,000 km) or six
months. For example, setting oil life start value to 60% sets the oil life
start value to 4,500 miles (7,200 km) and 108 days.
OPTIONAL MESSAGE CENTER (IF EQUIPPED)
chime.
Selectable features
Reset
Press this control to select and reset
functions shown in the INFO menu
and SETUP menu.
Setup menu
Press this control for the following
displays:
• Reset For System Check
• Oil Life
• Running Boards (if equipped)
• Autolamp
• Autolock
• Autounlock
• Language
• Reset to English (if in another language)
An oil change is required whenever indicated by the message center and
according to the recommended maintenance schedule. USE ONLY
(approximately 7,500 miles [12,000 km] or six months) perform the
following:
1. Press and release the SETUP
control to display “OIL LIFE XXX%
HOLD RESET = NEW”.
2. Press and hold the RESET
control for two seconds and release.
Oil life is set to 100% and “OIL LIFE
SET TO 100%” is displayed.
Note: To change oil life 100% miles value from 7,500 miles (12,000 km)
or six months to another value, proceed to Step 3.
3. Once “OIL LIFE SET TO XXX%” is displayed, release and press the
RESET control switch to change the Oil Life Start Value. Each release
and press will reduce the value by 10%.
chime.
Selectable features
seconds.
Setup Menu
• Oil Life
• Language
following:
NEW.
is displayed.
chime.
Selectable features
Reset
and SETUP menu.
Setup menu
displays:
• Oil Life
• Autolamp
• Autolock
• Autounlock
• Language
following:
HOLD RESET = NEW”.
It's actually pretty easy once you do it.
It looks complex on paper, but it's not.
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
gdkaufman
11-18-2016 04:15 PM
augim62
09-19-2016 11:09 PM
