Disc brakes instead of drums
Old 05-05-2010, 03:00 PM
Callantom's Avatar
Callantom
Callantom is offline
I have a 1993 Ford XLT F 350 4X4, crew cab, that has drum brakes on the rear and was trying to find out how to change this over to disc brakes. Has anyone done this and how expensive would it be? Thanks, Tom.
Old 05-05-2010, 03:45 PM
Virto's Avatar
Virto
Virto is offline
You'd pretty much have to fab everything up yourself, for practically no increase (if any) in stability or stopping power. Lots of labor, lots of trial and error and probably a healthy expense.
The vast majority of the braking in these trucks is handled up front. Upgrading those to larger discs and calipers might be a better use of money if you really want to spend on brakes.
Properly installed and adjusted rear drums are very effective. If you're having trouble with them, you might want to get them checked out.
Old 05-05-2010, 04:50 PM
Conanski's Avatar
Conanski
Conanski is offline
Maybe look for a complete disk rear end from a newer truck to swap in.
I'm not a fan of the drum brakes on these trucks either.. they never stay properly adjusted for very long and the additional rear brake power that disks provide is benificial when towing or carrying a heavy load.
Old 05-05-2010, 05:11 PM
86F150302's Avatar
86F150302
86F150302 is offline
^^^ What he said.
Old 05-05-2010, 05:51 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
do a search.
covered every few months and all come to same conclusion: leave well enough alone.
Old 05-05-2010, 06:24 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
I was having problems with my rear brakes not staying adjusted and then I changed out the self adjusting cable. I was surprised- even tho the old cable seemed tight, a new cable made a big difference. But that's on my 91 F150- and I don't do a lot of towing/hauling with it.
Old 05-06-2010, 06:00 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Like everyone else said, its a waste of time and cash. There will be little to no gain.
Old 05-06-2010, 09:00 AM
nstueve's Avatar
nstueve
nstueve is offline
I'd go with getting drilled and slotted rotors and a good set of pads for the front... It's the most effective upgrade you can do!
Old 05-06-2010, 11:00 AM
SaikotikGunman's Avatar
SaikotikGunman
SaikotikGunman is offline
TexasGuy is probably right, but every time I go to the salvage yard and walk past a newer super duty with rear discs and the same gears as my truck, I think to myself, "I wonder what he wants for that axle..."
Old 05-06-2010, 11:03 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
Drilled and slotted rotors won't provide more braking force under normal use unless they are larger than what you started with with better calipers.
Old 05-06-2010, 12:47 PM
nstueve's Avatar
nstueve
nstueve is offline
sorry I thought better calipers and larger than stock rotors was obvious... I'll be more clear next time.
Old 05-06-2010, 01:59 PM
SaikotikGunman
Less surface area... so actually LESS braking power under normal conditions.
Old 05-06-2010, 02:15 PM
jplinville's Avatar
jplinville
jplinville is offline
...but it keeps the pads and calipers cool during operation, so less chance of brake fluid heating up and failing.
Old 05-06-2010, 02:16 PM
nstueve's Avatar
nstueve
nstueve is offline
Yes but they vent the gas, dust, and heat out so the pads are more effective... And you have better "bite" on the rotor with your pads and the slots and drilled holes constantly sand off a little of your pads so they are fresh when you use them... IE: Not having a bunch of road dust and break pad debris built up in them... come on guy
Old 05-06-2010, 02:20 PM
nstueve's Avatar
nstueve
nstueve is offline
Typically there are 5 upgrades to breaks...
1.) better pads for a better bite on the disk
2.) better disks to keep pads clean and cool for better operation
3.) better calipers to help force the pads down harder on the disk
4.) better break lines
5.) power multiplier that adds extra force to when you put your foot down
Quick Reply: Disc brakes instead of drums
