North Carolina Chapter Join Chapter, Leader:Benztechnc
Link to BigLick
Old 05-03-2010, 02:13 PM
fuzzy1626's Avatar
fuzzy1626
fuzzy1626 is offline
Link to BigLick
Truck & Tractor Pull_Big Lick Festival Park, Oakboro, NC
For those who haven't been, this is the truck pulling event that Scott and I talk about. Check it out.
Old 05-03-2010, 07:26 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
YEEHAW. Cant wait.
Old 05-03-2010, 08:10 PM
fuzzy1626's Avatar
fuzzy1626
Which day are you planning on going this month Scott, 14th, 15th or both?
Old 05-05-2010, 10:01 PM
06silvercrew
15th most likley. I may swing by friday night but by the time I get out of work and drive home (45 minute drive) then another 20 the the pull It would about be to late.
Old 05-16-2010, 01:16 PM
06silvercrew
Had a good turn out last night. Didnt break anything so it was a success I guess. With my new tune that I just got I am SERIOUSLY running out of fuel, stock system cant keep up. Firday night the sled broke so we did some side by side dirt drag racing
Old 05-16-2010, 02:12 PM
fuzzy1626's Avatar
fuzzy1626
Good to hear the tune is working. How do you get more fuel with that PSD?
Mine is easy , you just turn the screw on the IP, but I can't make enough boost to to need more fuel.
Old 05-16-2010, 08:23 PM
06silvercrew
Its not fuel pressure that I am running out of, its volume. I can adjust my pressure anywhere I want too at idle but no matter how high I set it when Im on the fuel the system cant supply enough quantity. I need bigger pump and bigger lines from the tank to the engine. Thats not in the budget right now with twins on the way so it will have to wait.
