Chrome Clad Wheels - discolored
Anyone else have an issue with their chrome clad wheels? I have an 08 Expy EL with 20" chrome clad wheels and it looks like the chrome needs to be cleaned. The problem is it's actually under the finish and you can't clean it. They almost looked tarnished. I had a local dealer look at them and he agreed that they were bad. It' still under full warranty so, I'm going to try and take it back to the dealer were I bought it to demand replacement. Any body else run into this problem with the chrome clad?
image of wheel
http://ztekdesign.com/images/2008%20ford%20exp.JPG
image of wheel
Is it like that all over?
Do you have any car polish? Try polishing a small section and see if it improves.
Do you live where they salt the roads? Have you ever used a wheel cleaner? Those might corrode the chromed plastic. It's just a hub cap really and the finish is not strong at all. similar to the chrome on the plastic pieces on the hatch. I would make the dealer replace them.
I tried using a little chrome polish in one area, soap and water, windex, car polish. Nothing touches it. It's completely smooth surface. It's actually under the top finish. It looks to me like a bad chroming process. I live in Wisconsin and yes they do salt the roads here. If the rims can't handle salted roads and are going to look that bad after 26000 miles then Ford needs to stop using Chrome Clad plastic and go back to aluminum. At least that can be cleaned.
my rims looked somewhat similar due to brake dust and red dirt...but elbow grease and a bunch of chrome wheel cleaner and I got most of the crap off.
I thought for sure it was under my finish as well, and almost gave up on it. Didn't feel anything either.
hope you get lucky like I did. I'm going to pull my rims off 1 by 1 and do some serious table-top cleaning. I also used my drill and a buffing ball
I'll take one more try and getting some results but I worked an area the size of a fifty cent piece with some chrome cleaner I had and it didn't clean up at all. The dealer I talked to the other day said they recommend nothing stronger than car wash soap for cleaning. He also said they switched to chrome clad because it's easier to keep clean. The obviously got that part wrong. What kind of chrome cleaner did you use?
here ya go. it's tedious, but worked eventually.
I let my rims go dirty for a long time, so the cleaner had to soak a little bit. Just make sure the spray doesn't dry on the rim.
The spray foams on contact and clings to the rim pretty well. I just kept re-applying it and after about 10 minutes started scrubbing with a stiff bristle brush, then used the buffing ball on my drill.
image of wheel
image of wheel
The local dealer told me if the dealer I bought the Expy from won't help then he can see what he can do. He said being he is a very small dealer and Fords policy is to basically keep track of warranty cost per dealer it's almost a bad mark against a dealer to do warranty work. Because the wheels are so expensive it's a large warranty claim and he would rather I try the dealer I bought it from first. I have know the service manager at the local dealer for a long time now and he isn't trying to shove me off. I just wish they would have had a Expedition for me when I bought mine. Then he wouldn't hesitate to get something done. Just not very many newer used EL's out there. I don't blame him for trying not to show high warranty claims. Nowadays Ford is looking for any reason to get rid of the mom and pop dealers that are left. Just part of the politics we deal with nowadays.
Try some Fluid Film. It not only protects the chrome, but cleans and shines it up nicely.
No unfortunately these chrome-clad have some super nasa spaced aged as seen on tv mega bond and can't be removed. It's the entire wheel and not really a hub cap system. For cleaning I’ve used our magic eraser which seems to work well on these. I’d never use them on real chrome but it seemed to work ok with the clad ones.
