1966 F100 door tag decoding
Old 10-20-2010, 07:54 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by ibmorjamn
F10YR732707 "R" is San Jose plant what is "Y"
F10 = F100 2WD
Y = 352 2V (The D VIN engine code was used in 1965 only for the 352 2V).
R = San Jose CA Assembly Plant.
732707 = 1966, assembled August 1964.
Old 10-20-2010, 08:07 AM
NumberDummy
Originally Posted by croosteringa
Hey im new FTE and i just bought a 66 f-100 and trying to find everything about if someone can help me decode my door plate i would be gratefull
F10YN802261 // 115 / AM / F100 / D81 / 6 It's a G / 17 / 05000 / 172 / 4000 / 24
F10 = F100 2WD
Y = 352 2V
N = Norfolk VA Assembly Plant.
802261 = 1966, assembled January 1966.
115" Wheelbase.
A = Raven Black / M = Wimbledon White.
F100 2WD, 5,000 lbs, GVWR
D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic // 81 = 81B Custom Cab.
G = MX Cruise-O-Matic.
17 = Ford 9" Rear Axle / 3.25-1 / non Limited Slip / 3,300 lb. Rearle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @4,000 RPM
24 = Jacksonville FL Ford District Sales Office, where the original selling dealer ordered the truck from.
Old 04-14-2011, 12:38 PM
Clydesdale.bronc's Avatar
Clydesdale.bronc
Clydesdale.bronc is offline
Welcome to FTE
F10 = F100 2WD
A = 240 1V I-6.
C = Oakville, Ontario Canada Assembly Plant.
872431 = 1966, assembled June 1966.
115" Wheelbase.
No COLOR code.
F100 2WD / 5,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl // 81 = 81A Standard Cab.
F = Borg Warner T-18 4 Speed Manual Transmission.
A9 = Dana 60.3 / 3.54-1 / Limited Slip / 3,300 lb. Rear Axle Capacity.
129 net HP @ 4,000 RPM
172197:
17 = Washington DC Ford District Sales Office, where the original selling dealer ordered the truck from.
2197 = Domestic Special Order number. Your truck was special ordered by the original purchaser, not "bought off the lot."
When there is no COLOR code, the truck was painted a non standard color. When this occurs, the truck would be a special order.
D74E-DA = D7PZ9510BT .. 2V Motorcraft Carburetor (Motorcraft CA2212).
Original applications: 1977 Ford Granada / Mercury Monarch / Lincoln Versailles, all w/a 351W.
7F28 = Assembled June (F) 28, 1977 (7).
D9PZ9A586K .. Carburetor Kit (Motorcraft CT1261)
So I can take from his decoding that my 66 Crew is:
F25BC834394
F 250
C Oakville Ontario Canada
(Help me out with the 834 bit)
129" wb.
M color code (thinking Off White.. Ford code is coming to me but slowly...)
481 says "beater with a heater" e.g. not custom cab.
5800# GVWR
150hp/3600 rpm 300 c.i.d. 6
DSO
720695
F= t-18
B5 = 4.10 LSD...
Did I get her?
A little help with the DSO and an idea of Birth date off production number would be killer!
My "unicorn"
Old 02-22-2012, 10:30 AM
jage1965's Avatar
jage1965
jage1965 is offline
1966 F100 Decoding Door Tag
I have a 1966 F100 Custom Cab and am trying to figure out the original colors, were manufactured ect... Here is the info from the door tag.
F10BN746288
WB 115"
Color 5M
Model F100
Body E81
Trans C
Axle 08
Max G.V.W. 5000
Cert.Net.H.P. 150
RPM 3600
DSO 26
Thanks,
Jamie
Old 02-22-2012, 10:45 AM
jage1965's Avatar
jage1965
jage1965 is offline
1966 Ford F100 Color Chart and Link
1966 Ford Exterior Paint Colors
<CENTER>Metro Muscle Cars</CENTER><CENTER><TABLE width=559 cols=2><CAPTION>1966 Ford Exterior Paint Colors</CAPTION><TBODY><TR><TD><CENTER>
F - Arcadian Blue</CENTER></TD><TD><CENTER>
V - Emberglo Poly.</CENTER></TD></TR><TR><TD></TD><TD></TD></TR><TR><TD><CENTER>
H - Sahara Beige</CENTER></TD><TD><CENTER>
X - Vintage Burgundy Poly</CENTER></TD></TR><TR><TD></TD><TD></TD></TR><TR><TD><CENTER>
K - Nightmist Blue</CENTER></TD><TD><CENTER>
Y- Silver Blue Poly.</CENTER></TD></TR><TR><TD></TD><TD></TD></TR><TR><TD><CENTER>
M - Wimbledon White</CENTER></TD><TD><CENTER>
Z -Sauterne Gold Poly.</CENTER></TD></TR><TR><TD></TD><TD></TD></TR><TR><TD><CENTER>
F - Antique Bronze </CENTER></TD><TD><CENTER>
4 - Silver Frost Poly.</CENTER></TD></TR><TR><TD></TD><TD></TD></TR><TR><TD><CENTER>
R - Ivy Green Poly.</CENTER></TD><TD><CENTER>
5 - Signal Flare Red</CENTER></TD></TR><TR><TD></TD><TD></TD></TR><TR><TD><CENTER>
T - Candyapple Red</CENTER></TD><TD><CENTER>
8 - Springtime Yellow</CENTER></TD></TR><TR><TD></TD><TD></TD></TR><TR><TD><CENTER>
U - Tahoe Tourquoise</CENTER></TD><TD><CENTER>
A - Raven Black</CENTER></TD></TR></TBODY></TABLE></CENTER>
Old 02-23-2012, 12:30 AM
SuperSabre's Avatar
SuperSabre
SuperSabre is offline
Looks like you have a bunch of the info already,but here's the decode:
F10 = F100 2 wheel drive truck. B = 300 cubic inch 6 cylinder 1 bbl engine. N = built at Norfolk, Virginia. 746288 = built in September, 1965. 115 = wheelbase in inches. 5M = two tone paint. M = Wimbledon White. 5 may well be Signalflare Red based on your research and the thread by Boss9. However, one would expect a Domestic Special Order number for special paint at the end, and you didn't list it. F100 = 5000 lb GVW half ton truck. E81 = Custom Cab with red crush vinyl and red cody pattern woven plastic upholstery. C = 3 speed manual light duty transmission.
08 = Ford 9 inch non limited slip differential with 3.50 gears. 5000 lb GVW. 150 NET horsepower achieved at 3600 rpms. DSO 26 = ordered by Washington DC sales office. If there are four additional numbers after the 26 then it was a domestic special order. Hope this helps.
Old 02-23-2012, 12:40 AM
SuperSabre's Avatar
SuperSabre
Ooops, I screwed up in the last thread. If your truck were a domestic special order for special paint, there would be NO ENTRY in the paint spot on your door tag. Number Dummy would have earn me for breakfast! As mentioned in the Boss9 thread, 5M is a pretty unusual paint code.
Old 02-23-2012, 03:31 AM
fordpt's Avatar
fordpt
fordpt is offline
[quote=salvaged66;8795109]Thank you for all the information. Being that this was a special order, is there a way to determine the original color?[/Take the gauge cluster off should be original color behind it. You can also check behind radio bexel.
Old 02-23-2012, 09:48 AM
jage1965's Avatar
jage1965
jage1965 is offline
F100 2 tone
SuperSabre, thanks for the info!! Do you know if the 2 tone was always more red than white? Mine is actually the opposite.
Old 02-23-2012, 02:33 PM
NumberDummy
Originally Posted by jage1965
1966 Ford PASSENGER CAR Exterior Paint Colors
</TD><TD><CENTER>
V - Emberglo Poly. PASSENGER CARS ONLY
</CENTER>
</TD><TD><CENTER>
X - Vintage Burgundy Poly PASSENGER CARS ONLY
</CENTER>
K - Nightmist Blue PASSENGER CARS ONLY
</CENTER>
</TD><TD><CENTER>
Y- Silver Blue Poly.PASSENGER CARS ONLY
</CENTER>
</TD><TD><CENTER>
Z -Sauterne Gold Poly.PASSENGER CARS ONLY
</CENTER>
F - Antique Bronze PASSENGER CARS ONLY
</CENTER>
</TD><TD><CENTER>
4 - Silver Frost Poly. PASSENGER CARS ONLY</CENTER>
R - Ivy Green Poly.PASSENGER CARS ONLY
</CENTER>
</TD><TD><CENTER>
5 - Signal Flare Red PASSENGER CARS ONLY</CENTER>
T - Candyapple Red PASSENGER CARS ONLY
</CENTER>
</TD><TD><CENTER>
U - Tahoe Tourquoise PASSENGER CARS ONLY
</CENTER>
</TD><TD><CENTER>
The paint chart is Passenger Car related. Only 5 of these colors were also used on trucks, where are the other 7?
I have the original FoMoCo parts counter paint chip chart (the chips are glued to the page) for 1966 that covers Passenger Cars, Trucks, Bronco's and Econolines.
COLOR CODE = PAINT NAME ~ Trucks, Bronco's & Econolines.
A = RAVEN BLACK
B = CARIBBEAN TURQUOISE (no see um)
C = PURE WHITE (no see um)
F = ARCADIAN BLUE
G = CHROME YELLOW (no see um)
H = SAHARA BEIGE
J = RANGOON RED (no see um)
L = HOLLY GREEN (no see um)
M = WIMBLEDON WHITE
W = MARLIN BLUE (no see um)
3 = SKYLIGHT BLUE (no see um)
8 = SPRINGTIME YELLOW
This original (paper) page this chart was taken from appears to be faded, so the actual colors will not match.
You cannot go by digital internet pics of colors either, as some/most will not match in the real world.
Old 02-23-2012, 03:09 PM
NumberDummy
TYPO = Should read 1965
Old 06-18-2012, 05:26 PM
gearhead68's Avatar
gearhead68
gearhead68 is offline
message for number dummy could u decode this door plate for me please
f253mp b01203 133 mt f253 dd4 a 38j 1976 76
  #28
Old 09-04-2013, 06:52 PM
Waylon Fan's Avatar
Waylon Fan
Waylon Fan is offline
Could you please help with my vin F10JN613375
Wb 115
Color 0
Model 6100
Body D81
Trans A
Axle G2
*****i am needing to know what rear end I have. It has 10 bolts and drain plug on the back.
  #29
Old 09-05-2013, 04:28 PM
SuperSabre's Avatar
SuperSabre
You probably should have originated your own thread instead of tagging onto one that's three years old and might easily have been overlooked - however, since you're here, I'll give you what information I can: F10 = 2 wheel drive F100 truck. J = 240 cubic inch, 1 bbl I-6 engine. N = built at Norfolk, VA plant. 613375 = built in November, 1964. 115 = wheelbase in inches. O = exterior color Tropical Turquoise. Model 6100 is an error. Should say F100 = 5000 pound GVW rated half ton truck. D81 = Medium beige crush vinyl and light beige Cody pattern woven plastic upholstery (That's for a '66 - '65 is slightly different pattern.) in a Custom Cab. A = 3 speed manual light duty trans. G2 is probably an error. C2 = Dana 44 limited slip differential with 3.73 gears. You left off the bottom line of your warranty plate, but it's pretty self explanatory except for the DSO. Hope this helps!
  #30
Old 09-07-2013, 10:39 PM
NumberDummy
AXLE code cannot be G2 unless it's an F500/750 with an Eaton two speed rear axle.
1965 D81: D = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
Quick Reply: 1966 F100 door tag decoding
