Extended cab door won't open
I think he means the inside handle and the one in the door jam.
one of the cable ends finally wore out. It happened to me. take apart the door Like Lisa said and sometimes if you pull the cable tight then pull the handle, it will open.
The are over $100 from the dealer. comes as a cable/latch assembly.
I still haven't replaced mine, the door rattles a bit, but it opens.
Do you drill the rivets out of the handle on the door jam?
Ok, take out the two screws that hold the window latch and the top panel will pop off. Remove the two (or is it three? ) screws on the top lip of the lower panel. the rest is held on by clips, just pop off the lower panel and your in.
You can do all of this from the back seat with the rear door closed.
Let me go look, its been a while...
help
I am in the process of trying to repair my super cab rear pass. door.
I've got the panels off and pulled the top cable to get the door open.
Now taking the top latch off I got two of the three torques bolts out
but the bottom one won't budge. I've spayed WD40 on it even tapped
the torque fitting in but it won't move only stripped the bolt out.
What can I d besides grinding it off ? Drill it out or what ?
I'm at a loss a to how to proceed so any help is appreciated !
Thanks,
Robert
Thanks,
Robert
Glad you got it out. If you have one of those 90 degree swivel head breaker bars next time try applying pressure in the loosening direction while smacking the back side of the bar directly above the bit and fastener. Don't be afraid to smack it pretty hard several times. This will almost always break the torque with out stripping out the head. Course you have to do this before its stripped out. If you have already stripped it out sometimes the next size up bit will fit just enough to get the job done. Wouldn't do this with a ratchet as you'll end up with a handful of ratchet parts.
When my doors would not open. Looked at all the videos and read the post. But when I got both doors apart notice the ends were snapped but the cables them selves were not broken or frayed. Door would not open so I tried just pulling the cable to the side and making it a tighter pull.Cable was same length but now tighter to pull.It worked the door opened. So took some bailing wire drilled a small hole and tied the cable off to the door frame. Both doors work fine. That was about two years ago, today one door the bottom cable had the same problem and the same cable situation not broken or frayed just the top and bottom plastic pieces were broken so did the same tie off and the door works just fine. bailing wire and duck tape fix about any thing LOL. If both ends are just cracked and broken the plastic pieces only try it. Just a thought
Last edited by David Wall; 02-24-2015 at 02:33 PM. Reason: word of should have been off
Truck Guy99
10-21-2016 09:30 AM
hunter301
1999 to 2016 Super Duty
11-09-2013 09:02 PM
