Changing Fuel Filters on 6.0L
Went out this morning to change the fuel filters on my 6.0L. Bought the prescribed Motorcraft filters, all ready to go.
I read up on how to do the change, all the manuals, online, etc. Seemed easy enough.
First, got underneath the truck, and I do not see the water release valve. No lever to release the excess water!
Second, changed the filter engine-side without a problem. New gasket, new filter, fine.
Third, go back underneath to change the larger filter at the fuel pump and discover that there is no way on earth that I can get the new filter into a position to replace the old one, much less get the old one out. The front drive shaft (4x4) and the frame create a space much too small to fit the new filter in. And the brake, a/c, and fuel lines running along the frame prevent me from accessing the front of the pump at the filter housing from any other direction. WTH?
Now, I did not have time to lift the Ex and put her on stands to see if a sagging front end would create more space between the front drive-shaft and the frame. But other than that, I have no idea how to get to the filter-side of the pump.
I will try and take a pic later to show you. But until then, anybody else have a smart answer to this??
Please advise and thanks in advance.
EDIT TO ORIGINAL POST TO INCLUDE PICS OF PROBLEM:
Look at this picture....
Service Points - HFCM and Fuel Filters
See the flat brass plug? That drains the water. Then for the future, get one of these...
HFCM Drain Plug
Not sure what it looks like under your EX, my truck is tight also, just used short strokes and it worked, some have used an extension to move the wrench further back. Haven't tried that yet. Next fuel filter change will be different. And no, I didn't take a diesel bath. Used rubber gloves also.
Check Tech folder for more info.
HFCM Drain Plug
HFCM Drain Plug
HFCM Drain Plug
Guys, thanks for the responses. Maybe I didn't adequately explain myself. Let me try again:
I don't have a problem getting the filter cap off, I can unscrew the cap.
The issue is getting the old filter out of the pump and the new filter back into pump. The front drive shaft (4x4) and the frame create a space much too small to fit the new filter in. And the brake, a/c, and fuel lines running along the frame prevent me from accessing the front of the pump at the filter housing from any other direction.
I will take a pic and post, hopefully I will get a chance tomorrow.
there is room to do it with out takeing anything else apart try putting the filter and cap up there as two pieces instead of together
Do you insert the new filter partway into the housing, then bring the cap into position and snap the filter into the cap before screwing it on?
Edit - nice post fordtech08 (and a whole lot fewer words than me)
Here are some pics of my predicament:
You will notice that the space between the front driveshaft and the bottom of the frame prevent me from inserting the new filter into the space that leads into the pump. I have ruined this filter trying to find a reasonable place to put insert the thing.
Let me know what you think. Sorry, just cellphone quality pics.
No, not even close! Not unless I jacked up the front of the truck so much that the front-end sagged enough to give me space to insert the filter?!?!?! But I don't know if that is possible, I only have a standard jack.
If you jack up the car at the frame (letting the diff drop) it would create more room beside the filter.
Then go way down away from the filter where there is a bigger opening (because the drive shaft is tilted).
Slide out the old filter that way, then get the new one in the same way, while keeping it clean (maybe wrap it up?)
Tricky... I don't envy you.
Mine is on the outside of the frame rail and is the vertical type...
