Need a Speedo Gear
Old 04-02-2010, 02:12 PM
jschira's Avatar
jschira
jschira is offline
Need a Speedo Gear
The big fat one inside the tranny. For a 62 144 CID with the 3 speed and 3.50 rear end. 6 teeth.
Anyone have a good one they want to sell? One from a 62 Falcon has a slightly bigger hole and wobbles on the shaft just a little.
Thanks.
Old 04-03-2010, 07:19 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Speedometer: DRIVE gear = On the output shaft / DRIVEN gear = at the end of the cable.
There are two 6 tooth DRIVE gears (on the output shaft): One was used 1961/62, another in 1963/67.
CODR17285A This one is listed for 1961/62 / Obsolete / No Ford Dealer or obsolete parts vendor has any.
DOTZ17285A replaced B7C17285A This one is listed for 1963/67 / Available from Ford
The closest sources to you that have some are:
SAM PACK'S FIVE STAR FORD in Farmers Branch TX has TWO = 972-242-5117.
PARTS INTERNATIONAL in Farmers Branch TX has FIVE = 888-727-0418.
Antique Auto Supply in Arlington does not have any.
OUTLAW714
1999 to 2016 Super Duty
06-27-2016 07:43 AM
twigsV10
6.2L V8
21
07-05-2013 12:48 AM
640 CI Aluminum FORD
2009 - 2014 F150
40
08-19-2011 06:48 AM
weazel
6.2L V8
07-28-2010 07:32 AM
Quick Reply: Need a Speedo Gear
