1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Unibody guys
Old 03-29-2010, 03:42 PM
My First Ford's Avatar
My First Ford
My First Ford is offline
Unibody guys
Ok so trying to put the truck in a solid enough state to transport, so figured I would just go ahead and get the body mounting hardware....... Only problem is cant find any, so for those of you have replaced them what did you use?
Old 03-29-2010, 08:23 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
carolina-classics.com (800-598-4211) located in Durham NC shows cab mounts for Uni's in their catalog (page 13).
Old 03-29-2010, 08:25 PM
My First Ford
Thank you will give them a call
Old 03-29-2010, 10:26 PM
garbz2's Avatar
garbz2
garbz2 is offline
Unis use only the front cab mount the rest bolt directly to the frame rail with a 1/2" rubber on the underside of the rail.
Front cab mount
Rear cab mount at torque box with rubber missing
Mount near rear axle
Old 03-30-2010, 10:58 AM
My First Ford
Thank you garbz2 I can't see the pictures here but, will check them when I get home.
Old 03-30-2010, 03:34 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
No body produces mounts which are correct. Here's my solution. I wrote it a while ago so this is just a copy and paste. They were made about 1 1/2 years ago. So far, they are working great.
After finding out that the rubbers for a unibody are not reproduced and mine are toast I had to come up with something else. I found some neoprene spring rubber which is weather resistant,oil resistant, abrasion resistant and impact resistant with a durometer rating of 75A. Sounds like promissing stuff. I got some 6" long 2 1/2" diameter with a 3/4" hole through the center pieces.
I acquired the rubber from Mcmaster-Carr, McMaster-Carr
The original upper mounts look like they started life as a 2 5/16" diameter, 1" tall, with a 3/4" hole through the center and a 1 5/16" diameter, 3/16" recess in the top.
The original lower rubber looks like it started out as a 2" x 2" square, 9/16" tall, with a 3/4" hole through the middle.
I found that a chop saw does an excellent job of cutting rubber.
First I cut the top mounts to the 1" thickness required.
Next I had to cut the 3/16" recess for the 1 5/16" washer. The only thing I had in my tool box that would do this is a vast collection of hole saws. So I got it set up in my drill press, using a 3/4" hole saw to aproximately locate the center of the rubber followed by progressively larger (or smaller depending how you start out) hole saws, minding the depth of each saw, until I had the cut I needed. I tried a grinding stone for this operation and it did not work at all.
I used a carbide bur with my dremel to clean up the cut.
Now on to the lower rubbers. I could not find any square bars of rubber with the 3/4" hole so I just used what I had to make them. I cut them to the 9/16" thickness needed with the chop saw. Now comes making them square.
I used one of the old rubbers with a 3/4" spacer to approximate the cuts and made the cuts with the chop saw. The old rubber was removed while making the cuts to avoid damage toit. Do this until all for sides have been cut.
Old on left. New on right.
I did not worry about the 3/16" larger diameter (2 1/2" rather than 2 5/16") of the new upper rubbers. Hopefully it does not come back to bite me in the but. So now after many, many, many hours of labor the rubbers are ready!
The only other thing I decided to reproduce is the 3/4" od, .600" id, 1 11/32" tall spacer. I made this out of 3/4", .065" wall stainless steel tube. This one's easy measure twice, cut once with the chop saw.
I also purchased some grade 8 fine thread 1/2" bolts 4 1/2" long and grade 8 nuts to match. I was able to find the large od flat washers on the very bottom in stainless. I could not find the upper 9/16" id, 1 5/16" od, 3/16" thick flat washers in anything - steel or stainnless. I'll probably have a bud whip out a few on his lathe.
The bolts are only hand tight at the time of writing this.
So there. Hopefully this will help those unibody folks who need to replace cab mounting rubbers but can't find them anywhere.
Old 03-30-2010, 06:48 PM
garbz2's Avatar
garbz2
garbz2 is offline
Nice Job. How about make up a tech article for the archive. Just gave me ideas for my crew cab.
Garbz
Old 03-30-2010, 08:25 PM
Customcab's Avatar
Customcab
Customcab is offline
I agree with Garbz; great write-up; needs to be a tech article. Thanks for the link to the spring tubing. Never heard of it before.
Mitch
Old 03-30-2010, 10:07 PM
My First Ford
Thank you for posting up man
Old 04-05-2010, 10:18 PM
charliemccraney
How do I make a tech article? I can view articles but can't figure out how to create one.
Old 04-05-2010, 10:43 PM
garbz2's Avatar
garbz2
garbz2 is offline
PM Tim or Adrian and ask how.
Garbz
Old 04-05-2010, 11:45 PM
e-tek's Avatar
e-tek
e-tek is offline
Great find charlie - Thanks for the link! Lucky for me the rubbers I had to rebuild where kinda OK (it was everything else that wasn't!).
Iaff113
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
10-10-2016 10:50 PM
senix
2017+ Super Duty
17
11-09-2015 07:22 PM
militarymonark
Idaho Chapter
18
03-31-2014 11:19 AM
glruff
Delaware Chapter
32
12-31-2007 11:02 AM
betontheturtle
03-22-2007 10:28 PM
Quick Reply: Unibody guys
