Starter keeps turning with key off
My first guess is a bad fender mounted solenoid/relay. I had a lot of problems with that on my 84 f150 until I broke down and bought a Motorcraft brand. I went through 3 off brand versions within 2 years. If you will do a search for "fender mounted solenoid" (with the quotes) I think you will find a test procedure for it.
I have a similar problem.
Ok, I have a 1997 f-150 xlt 5.4L triton v8, about 2 months ago I started it up and the starter would not disengage, so i would have to shut the truck off and try it again and it would stop, just about 2 weeks ago I decided to do something about it, so I changed out both starter solenoids and my ignintion switch. but i still get the same problem, but now it turns over everytime the battery is hooked up (even without the keys out of it). I ran some tests on the starter relay fuse and some other wires. The power to the starter relay fuse is correct, (only power when key is all the way on) but even when there is no power to the fuse there is continuous power to the main power cable on the starter mounted solenoid, and im about to go crazy, i've tried everything. Can somebody help me????
#5 in the diagram is NOT an ignition wire per se, it is the wire that, when power is applied to
it, tells the starter solenoid to provide current to the starter motor. Red/blue stripe (at least
on gas engines) and should have power ONLY when the key is in the START position. Pull
that wire off the solenoid and do some tests.... that wire should have power only in START,
if there is power at any other time then the column-mounted ignition switch is suspect
(assuming no wiring problems between those two devices).
It sounds like you've got that much figured out... if there is power to the starter motor
anyway, that relay is defective and is sticking.
Yep, another stuck relay. I remember long ago someone figured out they were ruining the new solenoids by over-tightening the large nuts on the relay. The whole stud was turning inside the unit when they tightened it, making it stick. Other than that, it's just lousy quality solenoids(relays).
