99' 5.4 rebuild kit
99' 5.4 rebuild kit
Well heres the deal, just in the last 4 weeks my 5 4 has been going through the oil. Its not going on the ground. I've heard, what I thought was a lifter, now I think its something bigger. It used to quiet down after it warmed, but now its clacking all the time. I have since parked it and am looking to find a good rebuild kit. If im gunna do this, mite as well amp it up a bit. Does anyone have any leads on what I should do. The truck is gunna live its life pullin racecars to the track and a fifthwheel camper.
Before yanking the engine out and tearing it down, were you going to do any diagnostic testing to find out of you need a rebuild? At minimum I would start with a compression test and an engine oil analysis. This will tell you the condition if your rings, valve seats and bearings.
The tapping noise may be an exhaust manifold leaking, a cam follower (lifter), or a lot of things that have nothing to do with your loss of oil.
But if you just want to waste money march on, you're heading the right direction.
apt403
13
02-01-2014 03:43 PM
59flatbedford
11-01-2010 04:50 PM
