1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
Auto tranny reverse band adjustment
Old 03-01-2010, 05:31 PM
mfp4073's Avatar
mfp4073
mfp4073 is offline
I have the astg manual, and it seems like the only adjustment to the reverse band is the reverse servo rod. I honestly cannot remember from last year when I had it out of the truck. I know there is a screw/locknut combo for the overdrive and intermediate bands. I was expecting something like that for the reverse too. Can anyone confirm this before I pull the tranny?
Old 06-02-2010, 07:15 AM
g_k50's Avatar
g_k50
g_k50 is offline
Let's bump it and see.
What's astg?
Did you pull the tranny yet?
Old 06-02-2010, 09:24 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
I am assuming you have a delayed engagement or slipping on reverse? If so the adjustment is just a one time adjustment when the new bands are first installed. Modern bands are quite thin, and by the time they start slipping, they are usually toast and need to be replaced.
Old 06-02-2010, 05:35 PM
mfp4073's Avatar
mfp4073
mfp4073 is offline
What's astg?
ATSG is the Automatic Transmission Service Group (I spelled it wrong). They make transmission manuals that are really amazingly good. ATSG Home Page You can buy them from them directly or sometimes from tranny supply stores locally (like I did).
Tranny pulled and replaced with a used one. new one is working great. The adjustment for the reverse band is the reverse servo/piston. They make different ones with different length shafts, you put one in, if its out of tolerance you put a longer/shorter one in. BUT there are only 3 lengths/part numbers.
In my case it was limited engagement of reverse. I had several problems and have had other problems in the past. I declared the tranny a waste/curesed and got a new one!
benbuilder
13
06-19-2017 06:47 AM
78 PEB
02-12-2017 09:03 PM
gtstill
01-18-2017 07:04 PM
sleep_deprived129
05-02-2016 01:24 PM
hoytshooter119
10-27-2011 02:05 PM
Quick Reply: Auto tranny reverse band adjustment
