bypass fuel tank selector valve?
on
1 Post
Fuel Tank Selector Valve
No problem.
Just connect the feed and return to/from the engine to the feed and return to/from the Front tank. Two short fuel hoses and a few hose clamps should do the trick, only problem is you will have to cut all the connectors so putting the selector valve back later would be a pain to do. Maybe cut the lines a few inches away from the switch so you can splice them back together later.
There is very little pressure/vacuum on the return/feed lines (fuel pump is located at the engine). Keep your switch set to the front tank so your dash fuel gauge keeps working with the signal from the front tank.
Is your selector switch leaking? If not why not just leave everything and keep it set to the front tank?
Good luck,
Sebastian.
Good luck,
Sebastian.
ok, sounds easy enough. No, it's not leaking, I just have never had it switched to the rear tank and was trying to prevent any possible issues by doing so. Once I get everything situated, I will be the only one driving my truck, so just leaving things as they are and leaving the ftsv set to the front tank may be the smartest way to go. Thanks for the input
on
1 Post
Don't switch it
I will be the only one driving my truck, so just leaving things as they are and leaving the ftsv set to the front tank may be the smartest way to go. Thanks for the input[/quote]
If you have not used the rear tank in a long time you could open up a mess of trouble if you did use the switch. It may get stuck when you try to switch it and then you got a real problem not being able to get it back.
Leaving things alone might be the best thing here.
I always switch my tanks frequently to prevent the switch from fouling/sticking. Done that on both my trucks for almost 20 years, never had a problem.
Seb...
Seb...
on
1 Post
Fuel Selector Valve failure
I never had one fail so don't know what the symtoms might be.
My rear tank gauge has been acting up recently on my 91 F350. The needle starts to swing widly and show F as the tank goes below an 1/4 of a Tank. Eventually it goes to E The sending unit must be shorting out once it reaches the bottom of the tank. Front tank is ok so it has to be the sender unit in the tank. Oh well, a project for another day, I hate pulling tanks...
Seb....
on
not switching tanks.
switching tanks but fuel gauge reading incorrect tank.
air intrusion/rough running.
no fuel gauge readings.
semi working - but fuel returns to opposite tank that you have selected.
Need help
I recently bought a 93 f350 7.3 idi. Selector switch wasn’t hooked up in cab. I hooked it up and flip the switch. Now the truck is stuck on rear tank only. Found out there was a hole in the tank so rear tank is shot however I can’t get truck to switch back to front tank and run. I want to bypass the selector valve but got to get the truck back to front tank. Suggestions?
No problem.
Good luck,
Sebastian.
Good luck,
Sebastian.
You can always get rid of the electric tank selector valve. Check out this thread!
https://www.oilburners.net/threads/m...l-pumps.71152/
You can also buy a parts store replacement for the tank selector valve.
Switch sticking
Seb...[/QUOTE]
Hi,
Is there a way to unstick the valve?
Never tried to unstick one. I suppose you could try tapping on it while another person flips the switch back and forth from front and rear tanks. Worth trying, but it would be difficult to know if it switched properly. The gauge may switch to the other tank without moving the valve to the other tank. Gauge may read one tank while fuel is pulled from the other.
Here is a thread on taking the valve apart.
https://www.ford-trucks.com/forums/1412430-tank-selector-valve-rebuild-with-some-pics-2.html
Here is a good video
https://www.ford-trucks.com/forums/1...ing-valve.html
Charlie
Charlie
