Surging problem
Surging problem
Sorry if this was covered before but I'm using my iPhone and can't search forums for some reason.
I took delivery yesterday of a 2004 f-250 lariat crewcab fx4 and started noticing on light to medium acceleration it surges like I'm pumping the pedal. I guess I didn't notice it test driving cause I was on the floor most of the time. My friend who has the same truck except drw said it was clogged fuel filters. The problem is really noticeable when it's cold. The truck has 126000 on it and it is all stock. What do you experts think
on
late build has a sensor in the right valve cover (passanger side) this sensor is the icp sensor.
if the sensor is not there its going to be behind the the turbo on the high pressure pump cover.
a sticking turbo is not as bad as it sounds. most can be cleaned and reused. there are some posts on here about turbo cleaning.
this will take a few hours to do
Yeah I bought it off a lot as- is. Tonight it got real bad then when it would shift into overdrive it would almost shake you out of the cab at idle it sounded like it was running on six cylinders. So I pulled into autozone had them check for codes and nothing came up. I went ahead and bought the filters to change tomorrow. Got back in the truck and it wouldn't start. Called the tow truck and while I'm waiting for him I continued to crank on it after about 20 minutes it finally lit up it ran the same but got me home. I shut it off in the driveway and tried to restart it cranked awhile but finally started. I guess I'll see if I can get money back from the car lot.
Staytuned25
03-25-2011 09:04 AM
Truckin4life
09-08-2008 08:49 AM
