Blower Fan Speed Issues
Hi everyone,
I have an '06 F-250 with the Automatic climate control system. A few days ago, the fan speeds appears to stay at a very low constant speed until you turn the fan controller to the top position. The fan speed display shows 7 horizontal hash marks represents the fan speed to the fan goes to high only when I set it to position 7. Everything else appears to work correctly, ie. it will switch from vent to defrost to feet only. Any ideas where to start with this?
Thanks
Thanks
In searching other threads, the resistor pack for an Automatic Climate Control system is:
# 4C2Z19A706AA
or Napa # BR-348
Does that sound right?
The location for the resistor found reading similar posts is:
And, it is the item located inside the housing, just to the left (drivers side) of the fan motor and slightly behind the AC dryer where electrical fittings are plug in. It is bolted in with 2 - 5/16" lug screws.
Thanks for the help Team Hard, I really appreciate it!
4_Econolines
01-17-2016 08:47 PM
jumperbob
12-15-2014 11:42 AM
1Fordnatic
10-09-2010 04:44 PM
