1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Upper Radiator hose not hot and no warm heat
Old 02-21-2010, 09:31 PM
hgufrin's Avatar
hgufrin
hgufrin is offline
on my 99 Exp 5.4L -
I recently replaced my oil filter/radiator gasket. (the one attached to block under the oil filter) which caused a loss of coolant.
So I decided to unscrew petcock to drain the rest; not much came out. It was like the petcock was plugged.?. I finally topped off with only 2 fresh gallons of coolant.
In doing all this, is it possible that I got air into the system (like ive read on a post here somewhere)? If so, how do i get it out?
I ask because now my upper radiator hose never gets Hot to the touch and I dont feel it under pressure as I squeeze it. Most importantly, I am getting only lukewarm temperature out of my heater in the front and rear of vehicle.
Bottom line - did i screw something up while opening up the coolant system?
I do appreciate all your help.
P.S. - the temp gauge reads normal under full operating temp...
Old 02-22-2010, 05:21 PM
alloro's Avatar
alloro
alloro is offline
Received 4,187 Likes on 2,425 Posts
Yes it sounds air bound. Sometimes taking it for a good drive down the highway will get the air out because of the high coolant flow. If that doesn't work, try parking on a steep hill pointing uphill.
Texas Bob
05-13-2022 11:27 AM
rdenis
6.7L Power Stroke Diesel
22
06-28-2018 10:15 AM
ElMoco
46
11-28-2016 09:42 PM
KJNDIVER
61
06-02-2016 08:33 AM
96bigblueford
12-21-2011 08:42 AM
Quick Reply: Upper Radiator hose not hot and no warm heat
