During Regen what does it mean when I see White Smoke?
I just was a bit on the worried side. As long as there is no issue I am happy with that news. It has 37,700 miles on it and knock on wood no real issues other than I feel it does it's regen too often. But I do a fair share of city driving. Recently I have started using a cetane boost and it has helped the regen cycles a bit. Mileage is a small amount better as well.
i would have thought your white smoke was out of the TIRES!! Aren't you always on the throttle, and these 6.4s are STOUT!! (LOL)
I live in a humid area and the only times it has smoked was when the EGT probes were broken.
I can see it burning off moisture IF it would regen when it was first started up. But once you get going the exhaust heats up pretty fast and it'll burn it off anyway. I'd say you have a problem with an EGT probe.
FWIW, Mine went into regen every AM on my 55 mile drive to work. It would start before I left the neighborhood and not stop until I was about 10 miles from the office. This was mostly hwy driving too. It never smoked while doing this. Just consumed massive amounts of fuel!
The dealer finally found the bad EGT. They had suspected it for some time, but you know how it goes... If it ain't bad on their readout they can't replace it under warranty!
Well last week I was in Denver, CO. and after sitting for about 30 min. I started it up and it died. I thought it was odd so I cranked it again and it idled really rough about 250 on the rpm side. Called my service advisor and he advised me to let it sit for about a hald hour and try it again. The check engine light also came on. Long story short after it sat I cranked it and it ran ok even though the check engine light was still on. I arrived at the dealership in the springs and also told him about the white smoke. Got a call the next day and he told me that the EGR was stuck so they put a new one on under warranty. Hopefully with a new one it will lessen the Regens that I've been having.
