1999 Expedition Turn Signal/Hazard problem
I have searched the forums here & can't quite find what I am looking for. The turn signals & Hazard flashers have stopped working in my 1999 Expedition. Fuses are all ok. I can't seem to locate the flasher relay. Does anyone know where it is? Does anyone have a picture of the location?
Thanks in advance for your help!
1999 expedition flasher
Ok. I found the box & replaced the blue relay & nothing changed.
I did determine the following:
The brake lights don't work.
The flashers don't work.
The turn signals don't work.
However, the turn signals & brake lights both work when the flasher button on the steering column is in the on position.
1999 expedition turn signal blinker
I did replace the blue flasher. I verified that the part number on the blue unit was in fact the flasher.
If my turn signal switch is bad, why do the turn signals & brake lights work when the hazard button is in the on position, but they don't work when it is in the off position? And the hazards wont flash at all.
Thanks again for your help!
Do I need to remove the ignition key cylinder in order to remove the cowling that covers the steering wheel column? Thanks for everyone's help with this!
Multifunction switch R and R
Yes, the lock cylinder has to come out. Insert key and turn to RUN position; then insert punch thru hole in the lower steering column shroud and push the ignition switch lock cylinder release tab while pulling out the ignition switch lock cylinder.Twist the tilt wheel handle and shank and remove.Move gear selector to lowest position to access steering column opening cover.Release the four clips and remove the steering column opening cover.
Remove the upper and lower steering column shrouds. Remove the lower steering column shroud. Remove the upper steering column shroud.
Remove the multi function switch. Remove the two screws. Disconnect the electrical connectors. Remove the multi function switch.Then try to remember how you took it all apart!
