4x4 won't engage
Old 02-15-2010, 04:45 PM
cjcook's Avatar
cjcook
cjcook is offline
4x4 won't engage
I have a 03 f150. The light on the dash says its in 4 wheel low range but it isn't. I don't hear the ticking under the dash when I turn the shift ****. I replaced the transfer case motor last fall. The light on the dash will not go off when I shift back into 2h. Any ideas?
Old 02-26-2010, 02:23 PM
ddelong's Avatar
ddelong
ddelong is offline
I had a similar problem and I think that mine is finally fixed.
First, you must find an HONEST garage with a good code scanner and it will check the electrics making sure that electronically it is shifting in and out of 4X4.
Finally I found the problem in mine. It was shift electronically and it still would not get into the 4X4 but the mechanic found a cracked solenoid that is on the R/S firewall. There a 2 solenoids here. One for engaging the 4X4 and one for disengage. He changed only the engaging one ($50) and now I can get my 4 wheel drive to work.
Good luck!
Old 02-26-2010, 07:54 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
the switch moves two solenoids on the fire wall. they open and send vacuum donw a hose to the axle differential. there are two hoses on the center pumpkin area of the axle that work the "on- off" 4 x 4 cylinder to engage the front axle. take the hoses off and see if one has vacuum at idle when your in 2 wheel drive, and the other has vacuum when in 4 wheel drive. if you have vacuum, the cylinder is "stuck". If you have no vacuum, follow the hoses to the passenger fender well and then up to the fire wall. if hoses are o.k., probalby the solenoids are not working.
Old 02-26-2010, 08:09 PM
cjcook's Avatar
cjcook
cjcook is offline
We have more snow here in ohio tonight. I put the truck in 4 wheel drive and it worked. I don't know whats wrong but I will check everything out. I just hope it keeps working until the weather breaks. Thanks for the info.
Old 02-26-2010, 10:52 PM
steve(ill)'s Avatar
steve(ill)
mind is a little tempermental on going into gear. I come to a full stop, shift into 4 x 4, pop it inot neutral to let things move around, and it does fine. Without using neutral, it might work 75% of the time.
Old 02-27-2010, 06:24 AM
cjcook's Avatar
cjcook
cjcook is offline
Mine works when it wants to. I normally shift from neutral to drive back to park then hope it engages. I think my problem is out front though not in the transfer case. I've had the truck in 4lo and the front end was not pulling.
Old 02-27-2010, 07:18 AM
cowboy1997's Avatar
cowboy1997
cowboy1997 is offline
cj, crawl underneath and spray a little penetrating oil on the actuator shaft. it sounds like the actuator on the front axle is not moving freely.
Old 02-27-2010, 09:58 AM
cjcook's Avatar
cjcook
cjcook is offline
Will give it a try.
Thanks
shog
2004 - 2008 F150
03-19-2016 11:14 AM
sa_hobbit
1997 - 2003 F150
02-14-2015 04:20 PM
99F350bigorange
43
01-12-2015 04:59 PM
Big Sky
1999 to 2016 Super Duty
52
09-23-2014 07:23 PM
4x4greenbeast
17
05-22-2014 12:10 PM
Quick Reply: 4x4 won't engage
