Replace Cigarette Lighter with Power Port?
They are the ORIGINAL power ports. Way back when, the only access to power in a vehicle was through the cigar lighter. As more and more personal electronics came out that used cigar lighter plugs, the car manufacturers started adding dedicated "power points" to vehicles. (the rear ashtrays started to be deleted through the years as less and less people smoked, too) The Power points sometimes cannot use or operate a lighter, but are just for accepting the power plugs.
I remember that was one of the things that made the Cadillacs and Lincolns so cool back in the 70's and 80's. there was a ashtray and lighter in each door and sometimes also in the back of the front seat. If you had something that needed power, the points were everywhere. In my 1984 Town car that I bought new, there were a total of 4. most other cars only had one in the front.
So that cigarette lighter can also be used as a power outlet?? I was always afraid it might ignite the power adapter! (I know that is foolish, just a thing!!) I suppose I can just get rid of the actual lighter and then try different adapters to see which ones work. I know the power adapter for my iPhone does not work in the lighter. I will just have to test which ones do. Otherwise, I guess I could just replace it with a simple power supply.
So that cigarette lighter can also be used as a power outlet?? I was always afraid it might ignite the power adapter! (I know that is foolish, just a thing!!) I suppose I can just get rid of the actual lighter and then try different adapters to see which ones work. I know the power adapter for my iPhone does not work in the lighter. I will myjust have to test which ones do. Otherwise, I guess I could just replace it with a simple power supply.
Typically when there is a problem getting power to a particular device it has to do with dirt/corrosion of some sort in the outlet or a problem with the device plug. Many times you can achieve positive contact by rotating the plug in the outlet and/or pulling it out just the slightest bit at the same time.
D
I would get one of these and cut the cigarette plug and hard wire it to an ignition switched 12V+. This way you'll have 3 cigarette lighter ports and 2 USB power ports for your phones and tablets.
Bell Automotive Products 5 Outlet Power Station/Dash Mount | Product Details | Pep Boys
whiteboyslo
11-08-2014 05:03 PM
