351w 235 omc
on
Look for a capital letter cast into the outside/top corner of the head near the valve cover or between the first and second bolt. GT will be GT40 heads, R will be E5TE and T will be E7TE heads. If none of these exist you'll have to pull the intake and get the casting number from the underside between the inner intake ports.
on
No I meant outside the valve cover as seen in this pic. GT40Heads1 on Flickr - Photo Sharing!
If there is nothing there the casting number is on the head gasket side, so you have to remove the intake and and look under the intake ports with a mirror. Some examples can be seen in this pic.. http://farm4.static.flickr.com/3045/...e5db1341_b.jpg
I have exactly the same engine in my Jeep. It is a 1974 marine engine that i got free from a mechanic friend that has a boat shop.
I had the low end rebuilt with off the counter parts from any autoparts
stores. I used a 1978 flywheel and clutch parts bolted to an NP435/205.
I then added an Edelbrock performer top end kit, 670 truck avenger, shorty headers and HEI distributor. Happy with the results i estimate 350 HP and 400 lbs.
All parts are interchangable with any 351w.
GH
GH
