08 Expedition Aftermarket Limited Slip
Old 02-12-2010, 10:40 PM
clum553946's Avatar
clum553946
clum553946 is offline
Is there an aftermarket limited slip diff. for the rear of a 4x4 08 Expedition E. Bauer? Will this cause any problems if you install one?
Thank you.
Old 02-15-2010, 06:16 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
I think you can buy anything.
But I'd think it would mess up the traction control which isn't programmed to recognize it.
I think some limo versions (?) may have had factory limited slip?
Old 02-15-2010, 06:42 PM
GlassLeather&Wood's Avatar
GlassLeather&Wood
GlassLeather&Wood is offline
I would not worry with a limited-slip rear differential (this being my honest opinion)
4-wheel electronic traction control comes standard (bundled with the AdvanceTrac electronic mitigation suite) on all 4-wheel-drive equipped Expeditions. It gives the same performance as a limited-slip rear differential with none of the shortcomings. Also with it being a true 4-wheel system, it also gives the performance of a limited-slip front differential.
How 4-wheel electronic traction control is better than a LSD ...
1: It reduces drivetrain stress.
2: Driver control is not affected.
3: Less complexity means improved durability.
4: It can react faster than a mechanical limited-slip differential.
5: It will never lose its effectiveness over the life of the vehicle.
Some limited-slip differentials will lose their ability to transfer torque
as the internal slip inhibiting device (usually a clutch system) becomes
worn from use. Eventually they will revert back to a open differential, and
must be repaired.
If you want to improve traction, then a electronic locking rear differential would be a better choice. It would also complement the electronic locking center differential that comes standard with ControlTrac 4-wheel-drive.
With both rear wheels locked together, AdvanceTrac would not engage as there wouldn’t be any slipping between them. AdvanceTrac would continue to look after the front wheels and step in if either one lost traction.
Ford already has this setup in the 2009 Ford F-150 FX4. AdvanceTrac looks after all four wheels and steps in if any of them lose traction. If more traction assist is needed, the rear differential can be locked. Then AdvanceTrac just takes care of the front wheels, since the rear locker takes care of the rear wheels.
slhanks4
New Member Introductions
05-21-2014 10:23 AM
Robin K
12-20-2012 02:39 AM
WesternKyNobody
41
06-17-2010 08:40 PM
milehighford
02-18-2007 01:48 PM
RPar
11-01-2005 10:00 PM
Quick Reply: 08 Expedition Aftermarket Limited Slip
