Any difference between green and yellow antifreeze?
02-09-2010, 12:37 AM
on
Hi, just bought a 02 Screw with the 5.4l and would like to do a coolant flush. The manual says to use either green or yellow antifreeze? Is there a difference between the two?
Thanks
02-09-2010, 11:42 AM
on
My opinion, stick with the 50/50 mix of green and distilled water.
02-09-2010, 12:58 PM
yellow is the best fluid to use, however you can mix the two.
02-09-2010, 04:38 PM
on
"yellow" or gold antifreeze is typically a long life antifreeze
02-09-2010, 06:28 PM
on
Yellow antifreeze is G-05, and is backwards compatible to 1999 in most Fords.
Do NOT mix the two, if you swap between them make sure you do a thorough flush and use distilled water in both cases.
Either is fine, but you can go 50,000 miles on the yellow.
02-09-2010, 07:05 PM
they can be mixed but you don't gain anything from the gold coolant if it is mixed with the green
KarstenP
35
08-13-2018 10:50 PM
perryg114
07-04-2017 12:47 PM
kingeightclub
1999 to 2016 Super Duty
11-30-2016 06:05 PM
DBANDGB
06-21-2010 10:18 AM
Saxon
08-06-2004 11:15 PM
antifreeae ,
antifreeze ,
brands ,
coolant ,
difference ,
differences ,
f150 ,
ford ,
g05 ,
gold ,
green ,
mix ,
mixture ,
vehicles ,
yellow
