Ontario Chapter Join Chapter>, Leader: loudfords
Hey Jeff I need something.
Old 02-06-2010, 01:23 PM
Red Ford Truck's Avatar
Red Ford Truck
Red Ford Truck is offline
Well you know I installed the tilt steering,yes?
Well when I went to install the plastic cowling that wraps around the steering column and screws to the dash, guess what the straight steering column and the tilt steering column are different lengths where the shift and signal levers attach so the cowling doesn't fit I need a shorter one.
Can you have a look and see if you have one that will fit?
Thanks,
Rick.
Old 02-10-2010, 08:08 PM
truckfarmingcanuck's Avatar
truckfarmingcanuck
truckfarmingcanuck is offline
I don't have any tilt stuff out here right now Rick. I have an idea what you need but much like yourself I assumed they would be the same. Gonna have to take a look at a tilt a little closer next time I'm beside one.
TFC
Old 02-10-2010, 09:05 PM
Red Ford Truck
I'll be using the one from the black Bronco for now...
When I find it in all my parts bins but I'll eventually need one for the black Bronco, so I figured I'd ask now and some time down the road you'll come across one.
Rick.
70-360fe
10-26-2013 07:34 PM
NYBob
21
05-14-2010 09:26 AM
turner45
01-24-2008 06:50 PM
ky renegade
17
08-30-2002 11:11 AM
Jrock909
Aftermarket Products
07-24-2002 11:29 AM
Quick Reply: Hey Jeff I need something.
