Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Why is My Steering Heavy?
Guide to diagnose trouble and recommended solutions
2006 Hard steering
2006 Hard steering
I've got an '06 F150 and the steering isn't right with it. It has had a heavy feel and is almost like the power assist is only working half as good as it should. It's been like this for a couple months. I 've had all four ball joints and the steering rack replaced in the last month. It had the heavy steering feel before and after everything was replaced. It also doesn't recover itself on sharp turns, I have to turn the wheel back as I complete the turn. Could it be the power steering pump? I thought it was a mechanical device and it either worked or it didn't, maybe they get weak? Any thoughts would be appreciated. Thanks.
This my sound to easy but the same thing happen to me . 04 5.4, its the same feeling. took it to the car wash opened the hood an directed the spray on the steering shaft that connects to the [rack an pinion] where the UJOINTS are top an bottom. an my power steering came back!!! the only thing it could have been dirt an ice ...got home took a can of garage door lube sprayed the two jouints. its been TWO MONTHS..works great..
I also had this problem on a Camry the wouldn't straighten out on its' own after a turn. I had recently replaced the steering rack so it was suspect. Everyone I asked said steering rack so I pulled the steering rack out again expecting the shaft on the rack to be very hard to turn, but it was easy to turn. I then started looking for what else could cause the problem. I found the same issue as above(universal swivel). Toyota wanted $135. I told them to stick it and got out the WD-40. No more problems.
I just came across this forum today, I hope lubricating my steering shaft solves my problems.
EScott,
Note that PB Blaster is a penetrant and WD40 is a lubricant, even though they are often used interchangably. Using PB Blaster may bring your steering back for a little bit, but it will likely not have a lasting affect (like a lubricant will) and it may even accelerate the wear on the joint (especially if there are rubber seals anywhere on the u-joint). You may want to use WD40, or perhaps another spray lubricant instead of a penetrant.
EScott,
Hard Steering F150
Thank you for your advice. I had the same problem with steering becoming harder and harder with every day. I was going to replace the power steering pump, but found you posts. Two rounds of WD40 on both joints and some axle grease took care of the problem. Saved me some $$$$.
Hard Steering
Had the same problem the last 2 years. It starts when the weather gets above 70° and seems to clear up in the fall. No sign of it in the winter. When I do have the problem, I have found that white lithium grease works really well. That or garage door track lube. It's a known issue with these F150s but not enough to warrant Ford to recall it. Besides, it's only the steering column....and Ford gets about 3 bills for the part alone. The local dealer wants about 9 hours labor.
