1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
what is a COP????
Old 02-01-2010, 08:21 AM
Jbrown8988's Avatar
Jbrown8988
Jbrown8988 is offline
what is a COP????
truck is skipping...not at idle but when driving.....sometimes at idle it will bog down but then catch up again... i did a search and can't figure out what a cop is??
Old 02-01-2010, 08:33 AM
Danno77's Avatar
Danno77
Danno77 is offline
Coil On Plug or Coil Over Plug?
Old 02-01-2010, 08:39 AM
bbender85's Avatar
bbender85
bbender85 is offline
coil on plug. instead of having a couple coil packs with spark plug wires or a distrubutor and plug wires, there is a coilpack mounted right on each spark plug.
Old 02-01-2010, 08:46 AM
1buzzbait's Avatar
1buzzbait
1buzzbait is offline
yer kiddin me right?? coil on plug?? ddaayyuumm--i aways thought it was dem boyz in blue always chasin after me!!!
Old 02-01-2010, 08:50 AM
Jbrown8988's Avatar
Jbrown8988
oh ok what a dumb azzz i am!
yea i dont think its a coil....
dealer said look for a vacuum leak, so we are doing that now! I wish all it was was a coil! usually thats what is wrong but it is just acting different this time.
Old 02-01-2010, 08:52 AM
Danno77's Avatar
Danno77
Danno77 is offline
you SHOULD throw a code if it's misfiring due to coil problems. have you read to see if anything is "Pending"????
Old 02-01-2010, 09:10 AM
Jbrown8988's Avatar
Jbrown8988
no codes..... the pcv valve hose is sucking tight. We just put a new pcv valve in and still sucking the hose
Old 02-01-2010, 09:50 AM
1buzzbait's Avatar
1buzzbait
--no i didnt mean nuthin by that--i was bein a smart-azz--ya know cops--etc.--sounds to me like sumpthin is clogged to cause the pcv line to collapse!
Old 02-01-2010, 12:03 PM
Monster-4's Avatar
Monster-4
Monster-4 is offline
You will not get a CEL or any Code for a misfiring coil unless there is a complete failure of the coil. SD's are over 8500 GVWR and or not required to follow ODB II complience. See the link below.
https://www.ford-trucks.com/forums/5...t-come-on.html
If there is a misfire in a coil it will be stored as a Pending Code if there has been enough misfires. Most scanners can read the Pending Codes but it's a seperate menu from normal Codes.
Old 02-01-2010, 12:09 PM
Danno77's Avatar
Danno77
Danno77 is offline
Thanks for that info. I didn't know any of that, thanks for the link.
Old 02-01-2010, 12:18 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
COPs are those pesky little things with lights on the cars that never seem to leave me alone! lol
Seriously, the guys are right, it is Coil On Plug. It replaced the twin coil packs found on earlier model modular engines. Ford swapped out the packs to the COPs in 1999 on the Mustang, not 100% on the trucks. By the way, if the pack is going out, you might want to take a look at the boot. They are prone to failure causing the pack not to work properly. What may cost you $45 may actually be a replaceable $10 boot.
Old 02-01-2010, 04:03 PM
Monster-4's Avatar
Monster-4
No problem. When I first got this truck it took be a bit to wrap my head around the idea it was basically and ODB-I system with an OBD-II interface.
Old 02-01-2010, 06:40 PM
Danno77's Avatar
Danno77
Danno77 is offline
yeah, I'm looking hard at a 1999 F350. this will be a hard one for me to get used to if i get that truck....
Old 02-01-2010, 07:20 PM
johnnysF350's Avatar
johnnysF350
johnnysF350 is offline
Replace the pcv hose if it is sucking tight... They get soft with age, a good pcv hose is pretty firm and shouldn't suck closed.
Old 02-05-2010, 05:59 PM
slucas14's Avatar
slucas14
slucas14 is offline
Speaking of cop, the same one keeps cracking in my truck, 2001 350 v10, cylinder #10. Sometimes it will last a few months down to a day or 2, Am I putting it in wrong or doI have problems?
Thanks
Quick Reply: what is a COP????
