no signal to fuel injectors from pcm, replaced pcm and coils.
1997 Ford Expedition, PCM was replaced, along with both coils. I inject fuel manually an it runs but I dont have any signal from PCM, Red leg to injectors is hot.
I checked the PCM grounds and have no signal. The theft light continues to flash for an extended amount of time, longer than it used to, Do you think that it could be the key?
Hey, I'm cynical from having to work with people with more cents than sense (but not by much). It's not directed at anyone specific here (usually, although I might make exceptions).
There's your problem. PATS is not proving out and the PCM thinks the truck is being stolen. Consequently, the PCM disables the engine.
Since you say you replaced the PCM, it's probably safe to say you did not follow the correct procedure in the workshop manual. Either reinstall the original PCM (if it is not defective) or tow it to a dealer for proper programming.
