ZF shifter
ZF shifter
Hello guys, I have a 1988 F250. Truck is powered by a 460 and has the ZF S5-42 5 speed transmission. The shifter is simply worn out, has a lot of play and is at times hard to find the right gear. Anyways, I have been searching the net and E-Bay for a replacement shifter assembly with no luck. I would also be happy with a rebuild kit again with no luck. I am sure they are out there, but I have no idea where to look. Anyone got any suggestions or links I would greatly appreciate it. Also needing to replace the boot that bolts to the floor of the cab. Thanks again everyone.
Steve
Steve
Exploded diagrams and parts lists: http://www.zf.com/na/content/media/i...SpareParts.pdf
Cross reference chart to find the Ford number from the ZF number, so you can order parts from your local dealer (or online at something like y2kfordparts.com): http://www.zf.com/na/content/media/i...d_CrossRef.pdf
http://www.panix.com/~alvinj/file12/zfGS.jpg
Don't know if you are still messing with it or if others are interested. :)
Snugged mine up to at least like new, without buying any new parts!
Got some ideas and cautions. :)
The main caution would be to be sure you support the shift lever while
driving out the large pins, so you don't break the bronze cage. Worked
out good for me. :)
As you are finding out, ZF parts list are around with conversions etc, but
when it comes time to actually buy it, nobody seems to know what you're
talking about, unless it's a very common-to-replace part.
Alvin in AZ (born to tinker! ;)
out good for me. :)
Parts for your shifter?
Which parts?
Are they broken or just worn bad?
Alvin in AZ
Which parts?
Alvin in AZ
Actually, I have parts missing. In the top half of the shifter stub, attached with 4 allen head bolts both guides are missing. Not sure where they went, that is how I bought the truck. I crossed the ZF part numbers over to Ford and am currently on partsguyed.com getting them ordered.
If I could figure out how to post an image I would show you what I am talking about, but I will have to wait for my 7 year old daughter to wake up in the morning I guess. Not a big deal though, the parts are less than $10.
are less than $10.
are less than $10.
BTDT! LOL :) My son programs for IBM now and is using Linux BTW. :)
Be sure and post here in this thread the part numbers and descriptions
for us. There will be a record of them that way and I'll keep a record of
them too.
Anxious to learn what parts for a ZF are only $10, if nothing else. ;)
The little rubber boot F4TZ-7277-A was $22 and it had no metal parts,
just the boot. My new one ain't gonna go bad like the original did. I'm
going to protect it with a foam rubber collar like Ford used on my 75's
T18. :)
Bought the upper shifter boot F5TZ-7277-BA too $43 which turns out to
be a big and real fancy looking, piece of crap IMO. I'm going to have to
redesign it before I'll use it. It's just my tinkering nature prob'ly, others
might think it's the best designed shifter-boot ever? ;)
Alvin in AZ
Alvin,
The part that is missing on my trans is part #E7TZ-7C371-A and are listed as a "guide piece". I need 2 and I have found prices for them at 2 different places for $2.76 ea. Of course I am not going to get by that cheap because since I am ordering parts I am going to oder some other stuff also.
The upper shifter boot you mentioned part #F5TZ-7277-BA, I can not find it on the online parts catalog but do need one. Is that the boot that the shift handle goes through and does it include the plastic ring with the 4 screws that attach to the floor? My truck is a 1988. That is the only part I am trying to get a part number on so I can place my order.
Seems like it's a ~AA for diesels?
It comes with another part too, an internal sub-boot, which ripped on me.
And yes, the upper boot comes with the (cheezy ;) plastic base and four
screws.
Alvin in AZ
On my '90 ZF-542 with -188k miles on it in a company truck- there was
quite a bit of play/slop in the removable gear shift portion, here's what
I did...
The nylon blocks on either side of the bronze box/cage had eaten into the
bronze like crazy! The nylon blocks are hollow with sharp edges and I've
never seen anything like that wear before!
Didn't have a spot-facer tool that would remove the deep grooves around
the 10?mm steel pins, so I removed the pins and filed the bronze cage flat
and then heated the bronze cage and pushed the pins back into place.
I just hammered the pins out being careful not to allow the bronze cage
any chance to break.
To take up the space from the wear and filing -and- prevent future wear,
I carefully fitted thin-hard-steel washers (I collect stuff!;) that were
Dremeled (new verb;) to just fit over the pins. So all the slop was taken
up and future wear was prevented, all at the same time.
A tinkerer's proud moment if there ever was one. LOL :)
That's what was needed to take up the play in one direction the other
direction was simply a couple thin hard steel washers, seems like.
Alvin in AZ
ps- Thought about taking pictures while I had it all apart, but figured at
the time no one would prob'ly be interested in my silly tinkering.
pps- Besides, I did it without pictures and so can you. ;)
I did...
Alvin in AZ
