Tennessee Chapter Join Chapter Leader: harleymsn
got my eyes on a block for my motor build
Old 01-29-2010, 08:36 PM
nflfreak43's Avatar
nflfreak43
nflfreak43 is offline
well i think i found a block for my motor build its a 74 block out of a cougar. 351W Windsor small block with crank i was just on the phone for 10 minutes with the guy and the motor when pulled had a slight knock but when he disassembled it the connecting rod had started to come loose but no damage. he said the crank turns fine. i asked him bout how the cylinder walls look he said no scoring really but at the top of each cylinder wall there was a little ridge. idk if thats normal or not but he said i could probably get away with just having the block honed. gotta sell that dam downpipe so i have 0 dollars in this block. would be a great start.
so what do yall guys think? should i jump on the deal?
Old 01-30-2010, 07:12 AM
nflfreak43's Avatar
nflfreak43
well things may have changed. got a chance to buy a 72 351W with everything on it for 300 dollars running perfectly fine. only probably is its in canada. so idk.
Old 01-30-2010, 07:56 AM
torkum's Avatar
torkum
torkum is offline
Chris I'm asking cause I don't know, will pre-fuel injected heads match up to your intake? The ports on the heads to the runners on the intake is what I'm talking about. Accessories mounting can be a challenge also. Just trying to think ahead based on my own experiences from the past.
Old 01-30-2010, 09:32 AM
Talyn's Avatar
Talyn
Talyn is offline
I got a 302 powertrain 4x4. =)
out of my 95 obd1 with PCM.
Old 01-31-2010, 09:36 AM
nflfreak43's Avatar
nflfreak43
oh im gonna have GT 40 heads. MAF SWAP well look in my sig its all there what im gonna do now.
Old 01-31-2010, 01:08 PM
Customcab's Avatar
Customcab
Customcab is offline
Chris; I know time & money are hard to come by; but when you get a chance; need to travel up here as mention in previoius post to the cash for clunker yard off exit one.
My buddy got a complete runnnig 351 Cleveland with a C-6 (74 LTD I beleive) with all the attachements (PS, AC, and all brackets) for $500.
Mitch
Old 01-31-2010, 01:15 PM
nflfreak43's Avatar
nflfreak43
i found this motor that im wanting to swap EFI on and go....
Fully Rebuilt 302
the efi will come from this.........
Ford 302 5.0 complete engine & computer
Old 02-01-2010, 09:19 AM
KDPate's Avatar
KDPate
KDPate is offline
Chris,
Call me before you get into it deep. Will hand off "the notebook" and some valuable info on what you are wanting to do.......
Old 02-01-2010, 04:05 PM
maples01's Avatar
maples01
maples01 is offline
I'd love to fab up a fuel injection setup to a Cleveland, talk about a screamer, just be certain to put in the added oil line to the front of the block at the pump to the top rear at the pressure sensor to avoid main starvation at high rev.
A 302 is a great car engine, I want more in a truck, a 351 Windsor is nice, but a Cleveland is better, and a 400, well a built one of those is to just go nutz, forget 460, the 400 is lighter.
Old 02-01-2010, 04:34 PM
nflfreak43's Avatar
nflfreak43
well im not gonna get the fully built 302. after talking with ann we i decided to wait. she really wants me to have the experience/joy of putting my own motor together and made me realize thats the better decision for me. cause i would and she is right.
Old 02-01-2010, 05:04 PM
maples01's Avatar
maples01
maples01 is offline
I did one, a 351M on an engine stand, there is a great machine shop here in the Boro with great prices, have them do the cam bearings, it'll be $50 bearings included, and they'll install the cam for you. I have to say Mikes Speed Shop is pricey, I had them turn my crank, got by with 0.10, I don't suggest more than that, if it's that bad look for another. You can take your time building one as long as you keep it coated in a film of oil to prevent rust, have the machine work done first, then buy your parts, to insure a fit, I did a mild build. Now knowing the costs involved, you can get a re-manufactured engine cheaper, due to the high cost of machine work.
