adjusting front air susp on navi
from what i been reading there is a way to adjust the rear air susp by a inch or two in the back of the expy/navi with air susp, is there anyway to adjust the fronts? basically i want to lower the truck but just about a inch or 2 at most, wandering if its possible to adjust the air susp to achieve this?
See if this helps, I'll look for info on the rears next.
Front Ride Height Resetting — Clear B2140 DTC
Turn the ignition key OFF and turn it back to RUN; exit the vehicle, close all doors and allow the system to vent the vehicle down to kneel height (approximately 30 seconds).
Connect scan tool to the data link connector (DLC).
Select the proper vehicle year, model and engine type.
Select 4WAS-AIR SUSP/EVO (4x2 and 4x4) module.
Select "Parameter Reset Command (Clear Ride Height) under Active Command Modes" menu, trigger through the warning messages and reset (trigger from OFF to ON):
scan tool version 10.0 — "Front" and "Rear."
scan tool version 11.0+ — "Front CLR."
Back out the torsion bar adjustment bolt (approximately 40 mm from the bolt head to the bottom surface of the torsion bar adjuster).
Deflate the front air shocks by using the scan tool "Vent Front" command in "Air Suspension Control" menu (should take about 30 seconds), and jounce the front of the vehicle to fully lower the front of the vehicle.
Adjust and measure the vehicle ride height; refer to Section 204-01B .
NOTE: Do not save rear ride heights. The air suspension control module has precalibrated values already stored. Refer to Rear Ride Height Mechanical Resetting.
Select the "Save Calibration Values (Store Ride Height)" scan tool command to calibrate the air suspension control module. Trigger through the warning message(s) and save "FRONT" (trigger from OFF to ON).
Turn the ignition key ON.
Measure vehicle rear height (driver side) from the bottom of the frame to the rear jounce bumper bolt rear side of head base.
Using scan tool, adjust rear height to 146.8 ± 2 mm by moving the rear of the vehicle down using the active command ("VENT_REAR") or by moving the rear of the vehicle up ("LIFT_REAR") in PID RHGTSEN.
Monitor the rear height sensor voltage on the right side of the scan tool screen.
Loosen the ball stud nut on the rear air suspension height sensor bracket and adjust it by moving it with the air suspension height sensor up or down until the voltage is 2.66 ± 0.02 volt.
Tighten the ball stud nut.
Here's the info on the rears, good luck with it.
Rear Ride Height Electronic Resetting
- Connect scan tool to the data link connector (DLC).
- Turn the ignition switch to the RUN position.
- Select the proper vehicle year, model and engine type.
- Select 4WAS-AIR SUSP/EVO (4x2 and 4x4) module.
- Select the active commands menu "Save Calibration (Store Ride Height)." Trigger through the warning message.
- Monitor the RHGTSEN PID.
- NOTE: Do not press the trigger after selecting REAR.
Select REAR.
- NOTE: Do not disconnect the rear height sensor from the upper ball stud.
Disconnect the rear height sensor from the lower ball stud.
- Slowly compress/extend the rear height sensor until the rear height sensor voltage is 2.66 ± 0.02 volts.
- Press the trigger to save rear ride height settings (turn from OFF to ON); this will calibrate the air suspension control module.
- Perform the Rear Ride Height Mechanical Resetting. If the rear height mechanical resetting has been performed, clear DTCs and run On-Demand Self-Test.
nice...thanks! now i ran into a diff problem with the air susp today... jacked the front up to change the brake pads.... now the check susp lite is on and the compressor wont kick on?? i checked the fuse and disconnected the battery for about 15mins, still nothing? any thoughts on what could be going on?? when idling it sounds like i can hear the clicks from the solenoids up front almost, but nothing with the compressor.... before i jacked it up i never had one issue with the air susp?
(BTW, what year Navi(?) are we working with here?)
I'd check the fancy schmancy relay hidden up under the right front fender near the headlight. Pull it off and check it out with a battery for power and a test light to see if its pulling in.
About lowering 04 navi
Hi, how's it going, in really new to the navigator thing, but I have experience in raising and lowering trucks, but I picked up an 04 navigator cheap with blown suspension, but found someone selling a complete set of air shocks for it, but I definitely want to lower the truck a little , is there any way to modify the stock suspension to put airbags in, but I would like to know more about how u elongated the holes to lower ur truck and if u have any pictures of finished product or the process on how to do it I would b greatly appreciative, thanks for your time
Forscan bro download forscan hook the Navi up to. The computer air it up than unplug the power to the solenoids on each wheel and your all set if you can't hook it to the computer cut the airline at the compressor than stick a valve stem in the line and air it up at the gas station than unplug the solenoids and your gravy
ejjones55
15
03-04-2016 07:50 PM
Gwilkrrs
04-03-2015 07:35 PM
