Got my 56" flange to flange 9 inch rear end now i need axles.
Old 01-22-2010, 11:04 PM
nordvik72's Avatar
nordvik72
nordvik72 is offline
Ive been looking around for some axles for my nine inch but not sure of what it came out of. its about 56 inches from flange to flange so it will finally fit in bettween my fenders. i would like to buy a OEM type axle nothing crazy. i read in the articles above you could use '77-'79 T-bird, Cougar, LTD II, Ranchero, and '73-up Torinos left side (driver's side) axle but where do they sell them besides the junk yard.
Old 01-23-2010, 12:52 AM
HD74's Avatar
HD74
HD74 is offline
Currie, Currie Enterprises - Custom Rearends, Jeep/Off-road Parts, Crate Rearends, 4x4 Rearends
Old 01-23-2010, 07:19 AM
AXracer's Avatar
AXracer
AXracer is offline
Summit Racing - High Performance Car and Truck Parts l 800-230-3030 Ford direct fit rear axles, Alloy USA stronger than OEM < 100.00 each.
If the pumpkin is in the center of the axle (equal length axle shafts) it's likely out of a truck, unequal length likely out of a passenger car. There is plenty of ID info on the internet, you'll need to know if 28 or 31 spline, large or small bearing, bolt pattern desired. Even custom axles are not horribly expensive if you want a different bolt pattern or special length.
Old 01-23-2010, 07:56 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Hopefully you have the original nine inch truck backing plates, brake assemblies, and axle retainer plates because you will need them to use with the passenger car axles...
Old 01-23-2010, 11:20 AM
nordvik72's Avatar
nordvik72
yeah i do i had another 9 inch but it was alittle to wide.
patience
20
10-14-2015 07:19 AM
canadian_diesel1964
13
12-16-2010 06:15 AM
reed1951
04-09-2010 12:43 PM
hutchamatic
10-27-2006 11:38 AM
fatfenders56
04-04-2005 07:56 AM
Quick Reply: Got my 56" flange to flange 9 inch rear end now i need axles.
