Redesign and limited upgrade?
Old 01-18-2010, 11:07 AM
Joseph Dooley's Avatar
Joseph Dooley
Joseph Dooley is offline
Two questions...I see the Explorer should have the redesign released at some point this year, but not the Expedition. Does this mean we will see a new Expedition sometime in 2011?
Also, it looks like the blacked-out headlights and color coordinated grille that come with the Limited version are the same size as the XLT. I like them much better, if they are the same size, can I replace my headlights and grille with those from a Limited onto my XLT, or are they version specific?
Old 01-18-2010, 07:09 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
no idea about the re-design time-line. Ford usually leads the F-150 redesign with the Expy & Exploder. The current F-150 is only 1.5 yrs into it's run...and Ford typically does a 4 yr run on each major design change.
I personally am betting that the 2011 Expy will have a few minor changes (4 yrs from 2007 debut), and the 2012 will be a full redesign. by then, the 09+ F-150 will be slightly older and Ford will be regearing to change the whole lineup
as for the interchange...yes, anything you see on a XLT/EB/Limited/KR can be swapped from one to the other quite easily. The electronics can be a pain, but they all will bolt right up.
just be careful when going from a normal length to a EL.
Ford F-250
13
11-01-2012 12:21 AM
John_2004_EB
12-17-2009 03:46 PM
SoCalSuperCrew
2004 - 2008 F150
19
03-03-2005 07:38 AM
AG4.0
1983 - 2012 Ranger & B-Series
41
12-13-2004 02:10 AM
Monsta
1999 to 2016 Super Duty
26
10-31-2003 02:36 AM
Quick Reply: Redesign and limited upgrade?
