air in fuel lines f-250 7.3 diesel
Hi!
I've run out of fuel in my ford F250 7.3 diesel and now after refueling there is no posibility to start the engine.
Please tell me how to remove air from fuel lines properly.
I know that maybe this is silly and basic question but seriously I dont know how to do it. I was trying to find in this forum similiar thread but I didnt found.
thank you for any clues
The pump has lost it's prime. There's a chance you've also sucked debris up into the screens in the mixing chamber, so you may need to drop the tank soon and either clean the screens or do the intank mods.
To answer your question, filling the tank more than half way helps. Sometimes filling the fuel filter bowl (and replacing the lid) and cycling the key will help. Don't waste the batteries trying to start. The fuel pump is electric so turn the key on and listen to the pump. It will come on for 25 seconds, then shut off. Just cycle the key on for 25 seconds, then off, then back on again. You'll be able to hear the change in sound of the pump when it's primed.
Other options would be to disconnect the fuel line from the back side of the pump, stick a short hose on the pump and dip the other end into a container of fuel. Cycle the key several times to prime the fuel lines, then reconnect the factory line and cycle the key several more times. You can also blow compressed air at about 20 psi into the tank through the fuel filler neck. Wrap a rag around the blow nozzle to help pressurize the tank some and cycle the key. Don't make an airtight seal and don't over pressurize the plastic tank.
Another thought/possibility
If you haven't solved the problem by now. Your problem might not be fuel related but oil. The hi-pressure oil pump resevoir may have run out by "priming" the fuel system. Resevoir is on top front center of engine. Oil level should be about 3/4 inch from top (remove plug to check).
Mhintlian
08-27-2021 02:23 PM
Preston419
04-23-2017 07:47 PM
ExPACamper
07-24-2015 07:38 AM
rossistheguy
04-13-2015 12:05 AM
