5-lug wheels
Old 12-29-1999, 09:22 AM
damon's Avatar
damon
damon is offline
5-lug wheels
I have seen some late model ford 5-lug truck wheels on earlier model trucks. What model years are compatible with a '79 lug pattern? Any help will be appreciated.
Damon
Old 12-29-1999, 10:57 AM
j.frank
Guest
Posts: n/a
5-lug wheels
model A to 96 ford trucks all use 5&1/2 inch bolt pattern.
Old 12-29-1999, 07:08 PM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
5-lug wheels
I'll buy that this info is only good up until Ford quit building trucks in '97. All Ford 1/2 tons, Jeep CJ's, and International 1/2 tons have the same bolt pattern - 5 X 5 1/2. The only difference in the three makes is the center hole.
Ford's have the smallest, which is good if you drive a Ford cause then you can use all 3 makes. You can use a Ford wheel on the back of a Jeep but the front hub is larger and the center hole won't fit. You get the idea...
Trail Rider
Old 12-29-1999, 09:41 PM
mk's Avatar
mk
mk is offline
5-lug wheels
The only exception to the above, I believe, is the 80-81 F100's which had a 5" bolt circle. (same as car)
Old 12-29-1999, 11:00 PM
BigBrownTruck's Avatar
BigBrownTruck
BigBrownTruck is offline
5-lug wheels
I've had Dodge Wheels on a couple of Ford Trucks I've had. The Ford dog dish wheelcovers won't work on them though.
Old 12-30-1999, 08:39 AM
rick's Avatar
rick
rick is offline
5-lug wheels
I've seen many a 67-72 Ford pickup and van with the smaller 5" bolt circle, like cars, I personally think you'd be safe in assuming that "late model" wheels will fit back to ' 73, while we're on this subject what gives with the "standard duty" F250 as of late using a 7 LUG wheel ????
Old 12-30-1999, 12:14 PM
Chuck P.'s Avatar
Chuck P.
Chuck P. is offline
5-lug wheels
crazytwo
09-21-2015 01:39 AM
aj88V
01-25-2015 09:07 PM
kameronth
07-30-2014 10:58 AM
old uhaul
18
07-20-2014 09:16 PM
Quick Reply: 5-lug wheels
