Heater problems
Heater problems
My 09 F350 has had some heat and air problems and now the dealership is telling me that all fords do it and it is natural. Well I am wondering if anyone is having the same problems as I am. When my heat is on and set to a certain temp it will blow warm for a little bit and then get cold then get really hot. The truck is not set to auto so it should just blow at one temp. Also wile one side my be doing this when it is on duel the other side will have no temp change. I know of one other person that this is happening to but his problem is a little different. His vents and defrost will stay at a warm temp wile his floor vents blow cold. If you are having any of these problems or have herd of them let me know. Also if you have had none of these problems I would like to know also. The truck years that should be effected are 08, 09, and 10. Thank you for your help.
Lee
Lee
ttles714
12-19-2013 06:30 PM
QuadVan
15
01-16-2005 04:58 PM
