What axle is axle code H16?
Old 01-11-2010, 05:40 PM
jschira's Avatar
jschira
jschira is offline
This is on an 07 SSV Expedition.
I think that it is a 3.73, as all of Ford's 3.73 axle ratios end in a "6".
Bot LS or non-LS?
Old 01-11-2010, 07:16 PM
berry1234's Avatar
berry1234
berry1234 is offline
No Expys 07 and up have LS.
Old 01-11-2010, 07:48 PM
jschira's Avatar
jschira
jschira is offline
Thanks.
And a typo on my part. The axle code is H6.
Old 01-12-2010, 10:17 AM
berry1234's Avatar
berry1234
I stand corrected. The SSV does come with a LS. I assume it does not have the traction control also?
17 = 3.31 non-limited slip
19 = 3.55 non-limited slip
H6 = 3.73 limited slip
H7 = 3.31 limited slip
H9 = 3.55 limited slip
Old 01-12-2010, 12:38 PM
jschira's Avatar
jschira
jschira is offline
Now that you mention it, there is no "RSC" badge on the back liftgate.
Old 01-12-2010, 12:40 PM
berry1234's Avatar
berry1234
I think that for the RSC to work as designed, a LS would create problems.
Is this a personal vehicle?
Also, the Expy limos have the LS as well.
Old 01-12-2010, 02:53 PM
jschira's Avatar
jschira
jschira is offline
This is a truck that I am looking to buy. It was used as a security vehicle, either for a security company or at some mfg. plant.
Actually, the SSV's have some features that I like. The 3.73 (I tow). Column shift auto. Plain grille, wheels. Rubber floor mats (easy to clean).
The lack of RSC is not a deal breaker. My '97 does not have it.
Old 01-12-2010, 02:58 PM
berry1234's Avatar
berry1234
Yeah, you won't miss it. Does it have a bench seat? That would be nice, 9 seats.
Old 01-12-2010, 04:55 PM
jschira's Avatar
jschira
jschira is offline
No. Bench was only available in the SSV, but this one just has the console delete. So two buckets and a big hole.
Old 01-13-2010, 10:47 AM
berry1234's Avatar
berry1234
I guess to put radios and such. If you do end up getting it I would be interested in pictures.
Old 01-14-2010, 07:33 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
It has RSC unless it's a export model but even the models I've seen in the middle east has RSC.
FYI you can use RSC with a locker and limited slip (see the 09+ F-150).
Old 02-07-2010, 09:02 AM
jschira's Avatar
jschira
jschira is offline
Missed the Expy. Too much money.
Bought an '01 'Gator instead.
Walleye Hunter
05-24-2017 10:44 AM
Walleye Hunter
05-01-2017 03:17 PM
MT79
2015 + Expedition & Navigator
12-19-2016 08:17 AM
d_gant
2004 - 2008 F150
04-25-2016 08:24 PM
brentkhack
21
07-17-2014 07:27 PM
Quick Reply: What axle is axle code H16?
