Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Heat only works when engine is accelerating
Old 01-10-2010, 08:54 PM
Boba Fett's Avatar
Boba Fett
Boba Fett is offline
I have a 2004 Ford Explorer with a V6 and the heat only works when engine is accelerating.... the temperature is gauge reads fine and the blower works fine as well..... otherwise I got cold air.... any ideas
Old 01-11-2010, 04:12 AM
ncranchero's Avatar
ncranchero
ncranchero is offline
1.The cooling system IS full of coolant, isn't it?
2.Allow the vehicle to heat up with the HVAC controls set to "Heat" and temperature selector set to "Hot", blower on. When vehicle is at operating temperature feel the heater hoses. Are they both similarly hot or one hot/one cold? If the heater core is partially stopped up one will be hot, one cold/much cooler.
3. If the cooling system is full and both heater hoses are hot then you must have a vacuum issue.That can be a broken/leaking vacuum line or a defective selector control. Make a visual inspection of the small plastic vacuum lines under the hood and see if they're all connected and in good condition. You didn't say if you had the Manual or the Dual Automatic Temperature Control system. Post the answers to theses checks and we can go from there.
Old 01-11-2010, 05:07 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
It sounds like you have an air pocket in the cooling system and the reason you have heat under acceleration is inertia is causing the coolant to flow to the heater under acceleration. If there is a bleed valve in the system you may be able to evacuate the air, otherwise try loosening a hose that is topmost in the engine compartment. If you get air out you will have found your problem. This often happens after a cooling system service or thermostadt change.
Good luck with it.
Old 01-11-2010, 08:50 PM
cmaupin's Avatar
cmaupin
cmaupin is offline
Good luck with it.
it is like a it needs to be burped, air pocket, right?
Old 01-12-2010, 06:35 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
In my opinion.
BrodyUSMC
6.7L Power Stroke Diesel
02-23-2022 04:29 PM
Accessory Man
1999 to 2016 Super Duty
11-14-2016 10:09 PM
Fellenz
21
11-14-2016 09:09 AM
SCBrian86
11-19-2015 09:12 AM
Mike Parker
New Member Introductions
11-07-2015 12:23 AM
Quick Reply: Heat only works when engine is accelerating
