Front main seal 2002
It appears that I have developed a leak at the front main seal on my 02 7.3L.
It looks like it should not be too tough of a job, if my eyes are not failing me. I wanted to get some input on the job though...
I see a few bolts directly behind the balancer, is this a bolt on seal housing?
I've also seen that there is a front main seal installer tool. Is this really necessary to replace a seal that is in a removeable housing? I've seen these type of seals before, & all that is needed is a simple seal driver. Just wanting to make sure I don't get into a job that is going to require a "special tool" just to be able to complete it... <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Unless you just really want to tackle it yourself. I didn't have the time to mess with it and that seemed kind of cheap considering the effort I would have to put into it.
Your situation and expertise is obviously different...
Good luck!
I plan on getting under it tomorrow with a can of break clean, a few rags, & make daam sure it's the front seal. With what I saw this afternoon, it really looks to be the front seal, but now that I read thru these posts...I definitely want to take a better look.
It went from zero leak to dripping pretty steady in one day, I mean, I have had no drips or any other signs on the drive-way, & today, I have many "dollar size" puddles...
I forgot that there are oil lines on top of the engine...could I be so lucky as it to just be an o-ring?
Thanks again for the advice...
on
Ranger, If I recall the front crank seal is installed in the housing that holds the Low Pres Oil Pump. you have to disassemble the the oil pump to repair it. I would just by a new oil pump. comes complete with cover, gasket etc. just remove old-install new. about $60 from Ed or Melling has one out that is supposed to be slightly higher volume.
I think the NAPA one is a Melling also.
Its been a couple of years but this is a straight forward job. do it from underneath and you don't even have to pull the fan. I don't remember if you need a crank pulley puller or not. somebody on here will chime in with the info we need
Barney
Barney
It's nice & sunny here this morning, still cold, so I'm going to have a cup of coffee...or two...
Then I'm going to go out & clean up the oil off the bottom to see exactly where it's leaking.
I do hope it's just an o-ring, but if it turns out to be the front seal, I will definitely look into the whole oil pump replacement.
Thanks to all for the advice & input...I'm really liking this site
Barney
Well I checked it out...It is definitely leaking from the front seal. Oddly, it doesn't seem to leak with the engine running, but after I shut it down, & it sat for a while, it started to leak...go figure.
Thanks again for the input, & especially thanks for the PDF...that was a big help. I suppose I'll be tackling that this week...
