block heater location?
01-05-2010, 06:05 PM
on
hey guys. My dad has a 97 f250 and the block heater has stopped workin. Is there any common reasons these go out? Also where exactly are they located and are they hard to change out? thanks guys
01-05-2010, 06:08 PM
it's above the oil filter it's not bad to change you need to check the power cord
01-05-2010, 06:15 PM
on
Does the block heater heat the oil or anitfreeze?
01-05-2010, 06:31 PM
01-05-2010, 06:34 PM
on
Quote:
Originally Posted by
fordpride
antifreeze
Thank you.
01-05-2010, 08:52 PM
on
+1 check the cord, bet it's rotted
01-06-2010, 04:33 AM
I have had bad neutrals on the extension cord before. Also ohm out the coil it should be about 15 ohms.
L121andrew24
1999 to 2016 Super Duty
01-07-2016 05:43 PM
raygant
12-25-2012 10:40 PM
mongo12
13
12-14-2009 06:31 PM
daveyo
03-02-2008 11:10 PM
gameboynws
01-10-2004 04:52 PM
1997 ,
1999 ,
73 ,
97 ,
99 ,
block ,
diesel ,
f150 ,
f250 ,
f350 ,
ford ,
heater ,
located ,
location ,
truck
