1997 f250 5.4 late model
Old 01-01-2010, 08:18 PM
dbredinger's Avatar
dbredinger
dbredinger is offline
auto trans stuck in 4 wheel drive.
Old 01-02-2010, 08:07 AM
highteckredneck's Avatar
highteckredneck
highteckredneck is offline
you are stuck in 4wd? is it stick or push button 4wd?
Old 01-02-2010, 04:41 PM
dbredinger's Avatar
dbredinger
stuck in 4 wheel dr.
**** on dash board
Old 01-02-2010, 04:42 PM
dbredinger's Avatar
dbredinger
**** on dash board
Old 01-02-2010, 05:09 PM
highteckredneck
have you checked the relay for the t-case? could be you motor that locks it into 4wd. there has been several post here recently that has the same problem. just search for them and there was all you details about it.
Old 01-03-2010, 11:16 AM
dbredinger's Avatar
dbredinger
suck in 4x4
THANK YOU . I WILL LOOK INTO THAT.
Old 01-04-2010, 09:46 PM
SteevenH's Avatar
SteevenH
SteevenH is offline
Are you stuck in 4high or 4low?
Old 01-05-2010, 10:42 AM
dbredinger's Avatar
dbredinger
stuck in 4 high.
Old 01-05-2010, 12:28 PM
SteevenH's Avatar
SteevenH
SteevenH is offline
I would try 2 things. First have someone sit in the truck and you try to manually move the actuator on the differential while they turn off the 4wd. It should move out towards the driver's side when the 4wd
switch is turned off. If that doesn't work, put the truck in 4low and then turn the 4wd off and put the truck in reverse. If that doesn't work you probably have a bad motor on the transfer case, if it's getting power.
It's hard to tell without more info. Are the 4wd lights turning off but
truck remains in 4wd. That could be a solenoid or a vacuum actuator
problem.
351slug
Offroad & 4x4
03-16-2013 10:11 PM
Irish816
Offroad & 4x4
17
05-19-2010 08:08 AM
Offroad & 4x4
12-09-2006 09:03 PM
4x4x4x4
28
12-16-2002 01:54 AM
CustomCab4x4
02-03-2002 02:20 PM
Quick Reply: 1997 f250 5.4 late model
