Rear Window Washer
Under the carpet in the passenger side footwell is where the hose to the rear washer runs. It]s way up in the corner. It comes through the firewall and makes a 90 deg turn. Where it turns there is a 90 deg hose fitting. Check this fitting to see if it has come disconnected. Before pulling up the carpet you might want to check to see if it is wet. If the hose is disconnected in this spot it should be.
I have found with mine if I don't use the washer prior to "cold" weather the old washer fluid seems to freeze in the line. Once a semi warm day comes along and the fluid starts to flow the problem goes awayfor the rest of the season. And I use the -20 stuff year around.
Exactly what happened to mine this weekend. I forgot until I read this. I need to look at that tomorrow.
Hi Guys-It finally warmed up enough so it turned out I had blue washer fluid on the side of the passenger floor, so I pulled the kicker panel and sill strip, pulled the carpet back and reconnected the hose at the firewall. How it came unhooked is beyond me, it looks like it is a deep connection...
Anyways, my wife and I were talking about how this website has really been a God send. I have received so much help and advice on how to repair our Excursion and Super Duty over the years that it has saved us piles of $$$$ on repairing it myself. Thanks guys/gals for all your help. Happy New Year!
Excellent, and thanks for sharing the final outcome.
altascene
11-10-2016 09:05 PM
