Fuel pressure Regulator location
I have a 2002 F150 4.6 with the same starting problem that I have read about in previous post's about hard to start after shutting engine off and setting for approx. 30 minutes then trying to start again. I have narrowed it down to the fuel pressure regulator. I can cycle the ignition 4 or 5 times and it does start right up. However, from reading the posts I understand the FPR should be located on the fuel rail and be a easy replacement. Also looking at pictures online of the replacement FPR and the only thing that looks like the one it calls for is made onto the fuel rail on my truck. My question is has anyone ran into one that is made onto the fuel rail? It is possible that I am looking at the wrong part on the truck but this is the only one that looks just like the pictures but is not a quick change part. This one would require replacing the entire fuel rail assembly.
Thanks,
Thanks,
Update
Well I was wrong. After prying on it some more it does come apart as everyone has said. However it was not easy to come apart. The o-ring was holding it together better than one would expect. It two of us about an hour to get it to separate using different tools to pry with but it finally did separate from the fuel rail.
Cptn Rich
09-25-2020 07:05 PM
tsalley55
08-25-2015 08:03 AM
kirkharrod
12-10-2011 06:14 PM
fifthwheel01
09-27-2009 06:56 AM
