1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How to remove the key cylinder?
Old 12-22-2009, 09:13 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
Hey everyone,
Like the title says how do you remove the key cylinder on a 01 Ford Excursion.
Thanks
Nick
Old 12-22-2009, 09:20 PM
wallz's Avatar
wallz
wallz is offline
Nick, there is a small hole in the plastic cover under the switch. With the key in the ignition, in the run position you need to use an awl(or similar) and push in a small spring as you pull the cylinder with key out.
MONAVIERONJON
6.4L Power Stroke Diesel
08-27-2016 04:29 PM
bgwho922
07-13-2016 09:51 AM
indymike
12-08-2012 09:18 PM
Poison Oil Racing
01-20-2009 09:50 PM
B-DOGG
1983 - 2012 Ranger & B-Series
03-19-2006 02:10 PM
Quick Reply: How to remove the key cylinder?
