1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
6.0 making strange noise when I let off on the throttle
Old 12-21-2009, 02:53 PM
cynicel1's Avatar
cynicel1
cynicel1 is offline
If while going slow or from a stop I accelerate rapidly then suddenly release pressure on the throttle there is a loud noise from the engine compartment. It sounds like it is coming from the air intake area, maybe like a valve is slamming shut and causing the engine to choke. If I release the throttle slowly with no load on the engine this does not happen. Any ideas?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 12-21-2009, 03:00 PM
bpounds's Avatar
bpounds
bpounds is online now
Sounds like "turbo fart". That's a normal sound, particularly on a cold engine, although it is louder if you have an aftermarket cold air intake. Because these engines do not have a waste gate, excess boost pressure can backflow when you let off the throttle suddenly.
Old 12-21-2009, 03:31 PM
cynicel1's Avatar
cynicel1
cynicel1 is offline
Thanks for the response, sounds reasonable but I never noticed it before and now I hear it regularly.
Old 12-21-2009, 03:35 PM
bpounds's Avatar
bpounds
Do you have the original Ford air intake?
Old 12-22-2009, 08:32 AM
cynicel1's Avatar
cynicel1
cynicel1 is offline
Yes but I replaced the filter with a K and N filter.
Kart18
437
03-14-2018 05:20 PM
scottinjaxf250
15
08-30-2015 06:41 PM
TycoMax
16
05-04-2012 08:18 PM
AirborneCav
03-09-2011 08:00 PM
water 5
2004 - 2008 F150
02-28-2010 11:29 AM
Quick Reply: 6.0 making strange noise when I let off on the throttle
