hella 700ff install
Old 12-14-2009, 07:15 PM
bigtimebubba's Avatar
bigtimebubba
bigtimebubba is offline
hella 700ff install
Can someone help me on the install of these hella driving lights.
The directions they include in the box leave a lot to be desired. It doesn't help that this is really my first electrical install.
I have a 99 superduty. I hooked up all of the wiring harness in the engine bay of the truck. I wanted to make sure it worked before running the switch to the interior. I can't get any power to it. I got so frustrated that I pulled the entire harness and just left it on the counter in the garage.
Has anyone done an auxiliary light install that can help me out.
Old 12-14-2009, 08:27 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
I downloaded the manual. Do you want to try to install it again and then go from there?
Old 12-14-2009, 09:41 PM
bigtimebubba
Yes. Let me try it again tomorrow.
So each light needs to be grounded correct? The blue wire from each light.
Red wire on the harness plugs into the positive on the battery terminal
Green wire tap into on of the headlight wires. I chose to chanel lock the green wire on the headlight harnes
Yellow goes from the relay to the switch
The switch grounded. The blue wire
The relay grounded. The blue wire
Black wires from the lights connected to the black wire of the relay harness and goes to the relay.
What am I missing. Where should I be fastening the grounds for the lights, relay, and switch?
Old 12-15-2009, 11:00 PM
Franklin2's Avatar
Franklin2
So each light needs to be grounded correct? The blue wire from each light. yes
Red wire on the harness plugs into the positive on the battery terminal yes
Green wire tap into on of the headlight wires. I chose to chanel lock the green wire on the headlight harnes This should tap into the lowbeam if they are fog lamps. If they are driving I guess you could tap into the highbeam wire. Whatever wire you tap into, they will only work when that circuit is on
Yellow goes from the relay to the switch yes
The switch grounded. The blue wire no. No grounding blue wire from the switch
The relay grounded. The blue wire yes. To terminal 85
Black wires from the lights connected to the black wire of the relay harness and goes to the relay. yes. On terminal 87
What am I missing. Where should I be fastening the grounds for the lights, relay, and switch? Fasten the grounds to any metal piece on the body. Make sure you scrap the paint away.
BlowNdoh
07-30-2014 08:22 PM
blowhole
06-06-2011 01:11 AM
SpeedJunky
1999 to 2016 Super Duty
18
01-24-2007 11:10 PM
DS02F250
15
06-24-2004 09:23 PM
zippy the pinhead
Electrical Systems/Wiring
03-16-2004 01:11 AM
Quick Reply: hella 700ff install
