Why does 1 headlight work on low beam, but both work on high beam?
Old 12-10-2009, 05:58 AM
homer4.2's Avatar
homer4.2
homer4.2 is offline
Not that it really matters (I don't think anyways), but I have a 91 F-150 and got a problem. The title to the thread pretty much sums it up. Only my passenger side head light works when I have them on low beam, but when I switch to high beam both head lights work. Has anyone else had a problem like this or does anyone know how to fix it?
Old 12-10-2009, 06:10 AM
BigBlueOx's Avatar
BigBlueOx
BigBlueOx is offline
Each bulb has 2 filements, 1 for high beam and 1 for low beam. Just replace your bad buld and that will fix your problem. Unless in some unlikely chance you have a wiring problem. Try a bulb first.
Old 12-10-2009, 11:43 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
What he said.
Old 12-10-2009, 11:55 AM
Hitokori's Avatar
Hitokori
Hitokori is offline
yea u need a new bulb...... so buy 2 new ones that are relly good and bright
Old 12-10-2009, 12:59 PM
TexasGuy001
Just don't buy Silverstar or other blue tinted crap.
Old 12-10-2009, 01:06 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
i would go with these Ford F150 HIDs Ford F150 HID Kits Headlight Conversions Xenon Bulbs i wouldnt mind getting a set for my self when i get a J O B to pay for this stuff i wanna do
Old 12-10-2009, 02:20 PM
TexasGuy001
Those ebay retrofit HID kits are illegal. The optics of the headlight assembly are not designed for the HID bulbs. All they do is scatter the light and produce glare to oncomming drivers. This is why they are not DOT approved. Besides that the components are usually inferior.
You can find good information on improved lighting here.
Daniel Stern Lighting Consultancy and Supply
The best setup is running headlight relays with new OE style lense assemblies (not crystal clear or euro junk) and a pair of brighter bulbs like GE Nighthawk (not sport), Phillips Vision Plus or Xtreme Power or Sylvania Xtravision etc. These bulbs have the same wattage but a different filiment and gas mixture.
You can get the relays from LMC. They provide full power to the bulbs and carry the load so the headlight switch doesn't have to. This keeps it from overheating, which is a fairly common problem.
Old 12-10-2009, 02:32 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
where are u getting ebay retrofit kits?
Old 12-11-2009, 03:33 AM
TexasGuy001
I mean any of the retrofit kits that just have bulbs and ballasts to fit in the stock headlights. Its the same type of kit as what you linked to. Everyone just calls them ebay kits, because they are all over ebay.
The only way to properly retrofit HID into a vehicle that did not come with it from the factory is to replace everything except the switch on the dash. I don't think such a kit is available for our trucks.
Also, with most of those kits you only have low beams and no high beams.
Its just more hyped up garbage.
mechasus
Escape & Escape Hybrid
10-25-2021 04:06 PM
big-head
1999 to 2016 Super Duty
19
11-13-2019 12:39 PM
muscletruck7379
General Automotive Discussion
07-09-2012 06:19 PM
JKnSD
1983 - 2012 Ranger & B-Series
07-29-2011 05:04 PM
Weezman
1978 - 1996 Big Bronco
09-09-2008 05:04 PM
Quick Reply: Why does 1 headlight work on low beam, but both work on high beam?
