how to change the thermostat on a ford f-350 diesel 2003???
Old 12-07-2009, 07:18 PM
bjohnson's Avatar
bjohnson
bjohnson is offline
do anyone know where it is?
Old 12-07-2009, 07:20 PM
cheezit's Avatar
cheezit
cheezit is offline
ya follow the upper rad to hose to the engine at you will find it there.
Old 12-07-2009, 11:08 PM
03-6L-X's Avatar
03-6L-X
03-6L-X is offline
69cj did a nice step by step on how to remove it.
Thermostat Removal Option: (Thank you 69cj)
A) Pull air cleaner assembly.
B) Drain coolant.
C) Remove upper radiator hose.
D) Remove 2 nuts on t-stat housing.
E) Lift and move press sensor bracket to the side. Not a lot of play in it but it will move.
F) Remove 2 more nuts on t-stat housing.
G) Remove housing. It will lift right off of the studs.
H) Reverse procedure to re-install. Use a new O ring (5 bucks at dealer). I used Vaseline to hold the O ring in place.
Old 01-06-2010, 05:55 PM
Jayson250's Avatar
Jayson250
Jayson250 is offline
thermostat question
my ford 6.0l is running cool so would it be a thermostat problem it seems as tho its stuck open cuz there is a lil heat from dash but not much just wondering if thats the problem
Old 01-06-2010, 06:00 PM
69cj's Avatar
69cj
69cj is offline
Could be, did you check the coolant level? Low coolant can cause heater to run cold.
Old 08-22-2010, 12:45 AM
Ed31's Avatar
Ed31
Ed31 is offline
Mine was running hot today pulling many long hills. I think it might be sticking closed, gonna change it out in the part store parking lot as I'm on vacation. If they don't have it would it be possible to run without it until I can get one in a different town?
Old 08-22-2010, 07:41 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,371 Likes on 2,076 Posts
Welcome to FTE bjohnson and Ed31 Be sure to check out our Tech Folder located at the top of the forum, enjoy your stay.
Old 08-22-2010, 08:31 AM
69cj's Avatar
69cj
69cj is offline
Not a good idea but if you have too you have too.
Old 12-06-2010, 11:14 AM
Jayybird's Avatar
Jayybird
Jayybird is offline
I am thinking about replacing my T-stat as well. I have about a 20 min commute in the morning to work 55/65 mph. My ECT's are holding at 178. That seems too low. I didn't really notice this back in the summer when its hot. I assume this due to the thermostat sticking. If i run it up to 75 mph and hold it there, ECTs run up to the upper 180s but not much more.
Also, I've noticed my fuel economy has dropped since I started noticing this....would that be a coincidence??...I assume not as the engine should be more efficinet once at operating temp.
Would yall recommend changing the t-stat for this one?
I've read seveal posts and these temps seem to be a little different for everyone. As for now and what i am basing my decision on is the ECTs should be 190-200 and EOT should be 200-210 under normal operating conditions without a load and should have a max of 15 degree difference between the two...anyone disagree with that.
Thanks
Old 12-06-2010, 12:56 PM
03-6L-X's Avatar
03-6L-X
03-6L-X is offline
It's winter and every year about this time my mpg's go down. When the temperature does not get past 50*F during the day you cannot expect good mpg's.
Old 12-06-2010, 04:02 PM
mixerdrvr's Avatar
mixerdrvr
mixerdrvr is offline
Thanks
I have the same problem you have, only get to 174/176. Everything I have read says it is the thermostat getting weak/opening early. I am just waiting for a day in the upper 40s to get a chance to change it! may be next spring. it was 16 this morning!!!
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Roachfood
03-11-2002 10:21 PM
Quick Reply: how to change the thermostat on a ford f-350 diesel 2003???
