88 F350 Fuel Pump or Ignition??????
#31
<!-- BreadCrumbs are not required if we are coming through punchout --> › ACDelco Fuel Tank Selector Valve
******** language=javascript type=text/javascript src="/wcsstore/CVB2BDirectStorefrontAssetStore/javascript/jquery.jqzoom.pack.js">*********>******** type=text/javascript> $(function() { var zoomOptions = { zoomWidth: 235, zoomHeight: 235, showEffect: 'fadein', fadeinSpeed: 'medium', hideEffect: 'fadeout', fadeoutSpeed: 'fast', title: false } $(".jqzoom").jqzoom(zoomOptions); }); *********>
<FORM id=addItems name=addItems action=OrderItemAdd cM1="7">
******** type=text/javascript> var pr_page_id='-49883718'; var pr_data_callback = function (info) { if (info.getFullReviewCount() > 0) { document.getElementById('hasReviews').style.displa y = "block";} else { document.getElementById('noReviews').style.display = "block";} }; POWERREVIEWS.display.prData (pr_data_callback); *********>
<!-- Start - JSP File Name: CatalogEntryPriceDisplay.jspf -->$134.89
<!-- End - JSP File Name: CatalogEntryPriceDisplay.jspf -->
ALL MAKES; 6 PORT MOTOR DRIVEN FUEL; USED WHERE RETURN LINES ARE REQUIRED, 12 VOLT @ 60 PSI MAX
this is one that advanced has
it looks nothing like whats on my truck but i dont guess u need the little filter that is garbage cause it leaks
</FORM>
</FORM>
#33
#34
#35
#36
The fuel selector valves that "Hitokori" posted will not work. The first one is for for a Carburetor engine and the last one is for a Carburetor 460 or a Diesel engine.
Neither one has a Reservoir for the High Pressure Fuel Pump that is needed for the fuel injected engine.
No local auto parts store will have the right selector valve, You have to get it on the Internet or order it from a Ford dealer.
More information on the selector valve:
http://www.stangler.com/motorsports/...alve/index.htm
On the 88 the pump is on the left and the filter is on the right in the photo below.
#37
Sorry for the delay, computer went haywire for a day. I bypassed the selector valve and it runs perfect!!!!!!!! We ended up finding it by hooking up a fuel pressure gauge and driving it down the road, it was at 40 psi till you hit the throttle and it went to 15 psi. I put an inline filter in and all should be ok for now. Thanks for all the input from everyone, espeacially bill (subford) you pointed me in the right direction. One more question though, can i put a manual valve on that or is it worth the money to replace it? (not sure if i trust putting another one in)
#38
You need a Reservoir for the High Pressure Fuel Pump that is needed for the fuel injected engine.
It will run OK with out it except at WOT when you need the extra fuel.
Even the single tank trucks and Broncos have the non switching Reservoir.
If you do wire up a solenoid valve you will still need the booster pumps in the selected tank running for priming the high pressure pump and for going up hills.
Also you will have a return fuel problem as the solenoid valve does not have a select fuel route for the return fuel to the right tank.
#40
Just an update, been busy again with goose hunters, finally figured out it is the selector valve. Now the the problem is price and availability. The dealer wants $195.00 and a 5 day wait! Does anyone know if there is aftermarket parts and maybe where to get them? Thanks for any info!!
#41
We hooked up a fuel pressure gauge and ran it outside the hood so we could monitor what it was doing while driving, when the pressure dropped from 40 to 15 psi when you stepped on the gas, we decided to bypass the selector valve just to make sure that was the problem (we had already replaced and checked the boost pumps & the high pressure pump for pressure)
#42
I remember now you now you said that above.
Did you check to see if the boost pumps were running and had 5-8 PSI on the supply line from the tank?
Without this pressure the valve will not switch.
I think you said the valve had a filter in the bottom, did you replace it or do away with it if you put on an in line filter?
#43
chillman88
08-09-2015 02:02 PM
kedynskrow
16
11-11-2014 12:23 AM
f150light
09-26-2014 03:27 PM
