New Alternator and new battery wont charge or hold charge
I have a 1999 Ford F-250 started off with battery going dead so checked alternator and battery and found out the alternaor was done so put in a new one and that didnt fix the problem so then figured new battery so tried that and also problem not solve so theirs a brand new alternator from ford and new mastercraft battery anyone know what could be wrong.
I just changed the alternator on my 99 Ford F150 and there are 3 connections to the alternator from the battery. One is an eyelet with a stud and nut and that would be easy. The other is a plug that cannot be placed incorrectly but the 3rd is a single wire connector. Maybe it is not connected???
The voltage regulator is integrated into the alternator so that couldn't be the culprit.
If it is not the cable connections, it could be in the cables from the alternator to the battery. One could be broken.
Ballerforlife911
16
02-18-2010 06:46 PM
